Results 1 to 7 of 7
Thread: About 10 days in...questions...
    Jul 2013
    Princeton, NJ
    26
    Hey guys/gals,
    So I decided to go the TFP way.
    I've been testing my water every day, usually twice.
    Within the first 5 days I got my CYA up to ~35. I used the instant liquid stuff, which worked great...the dot test on my TF100 (or whatever the test kit they sell here at the store) took a little getting used to, but it's pretty consistently ~ 35.
    Every morning I've increased my chlorine to ~4 and every morning it's back down to about 1.5, which (according to the calculator) means I need to dump in ~ 30oz of bleach.
    pH has stayed consistent ~ 7.8 and TA is around 160.
    Is it normal to have to use 30 oz of bleach EVERY DAY?
    Also, this morning I noticed my water level was down a tad...not much, but a bit. I haven't added any water since completing the fill-up 10 days ago...is it normal to lose any water? Evaporation or what not...we haven't had much rain.
    Thanks!
    24' Above Ground Pool
    13,500 Gallons
    3/4 HP Hayward AC40 DE Filter
    Last edited by SubliminalME; 06-24-2014 at 08:13 AM. Reason: Add signature and location info
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    Re: About 10 days in...questions...
    No information can be given unless pool statistics are given.
    Information like in my signature.
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    2.5 FC loss per day is well within normal, especially if the pool gets a lot of sun and/or swimmers. If it has been windy and the pool is uncovered, you can easily lose over an inch a week. When we get the hot, dry Santa Ana winds in SoCal, the water really evaporates fast. Where do you live? If you fill out your signature, it will really help us and eliminate a lot of wild speculation.
    Jul 2013
    Princeton, NJ
    26
    Sorry about that...you'd think after being on forums for years I'd know better.
    13,500 Gallons
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    I am using 20-30 oz chlorine everyday. I don't have much evaporation here, as humid as it is here....I think the air puts water back in the pool LOL!
    Jul 2013
    Princeton, NJ
    26
    So basically there is no rest for the weary with this... Test and add daily. What happens if you leave town for a few days? Just super dose before you go?
    13,500 Gallons
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Only Suggestion I have is to base your target and "minimum" FC targets on this
    http://www.troublefreepool.com/conte...art-slam-shock
    I'd aim for 5-5.5 if you're losing 2.5/day that'll bring you to 2.5-3 min.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
