Thread: New motot or whole new pump?
    After a day or two of making high pitched squealing sounds, my Whisperflo Dual speed pump motor finally died. When I try to power it up it just hums. The model of the pump is WFDS-26. It's about 13 years old. I can buy a new motor, shaft seals and gaskets for about $400. I can buy the same exact pump for about $620. So here are my questions:
    1. For a $200 difference do you think I should buy the whole new pump, it seems like a better deal to me.
    2. Is there a better pump out there for my money?
    3. The only water feature I have is a pool slide, and the current pump, 1.5/ 0.25 hp, had no problem sending enough water to it.
    4. I'm not inclined to upgrade to intelliflo for a third more in price
    I did call my pool guy when the pump first started acting up 2 days ago, but he hasn't gotten back to me yet.
    Any and all advice appreciated.
    Tom
    In gound vinyl L, ~41,000 gallons, Pentair Clean and Clear Plus 420 cartridge filtter, Pentair 2 speed WhisperFlo pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: New motot or whole new pump?
    The bearings and seals on your motor are replaceable. No need to replace the motor at all.
    Thanks John. Is there a way for me to know if that's the issue? Can you provide a link for these parts? Thanks for the quick response.
    Tom
    SW Indiana
    9,198
    Usually easier to take the pump to a pool store or motor shop to be sure you are getting the right thing. Parts change over time.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    It could be the start capicitor, try turning the shaft, it should turn easily/smoothly.
    You can find a rebuilt 2 speed with warranty for a significant savings, here's a new one.
    http://www.ebay.com/itm/1-HP-2-Speed...item2329ff6e85
    Local pool store will mount here for approx $20. Don't forget to get a new shaft seal also.
