Results 1 to 10 of 10
Thread: Quick question in regards to foam cove/walls/floor
    Hey guys, I have decided to do foam wall covering, foam cove and foam flooring instead of sand.
    What is the correct layering to do in this case?
    These are the options I see:
    1) Foam floor first, the cove on top of that and then the foam on the walls.
    2) Foam on the walls first, foam floor, the foam cove.
    3) Foam on the floor, foam on the walls, foam cove.
    I am leaning towards #3 being the most logical (as in there would be the most give and evenness between the mating areas), and if I had a sand floor I can see putting down the foam cove first and then the sand on top of it (since the cove keeps the sand from washing out in that case), but what about an all-foam installation?
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: Quick question in regards to foam cove/walls/floor
    #3 sounds correct to me. Look at the cove like wall base board trim... you cant apply wall trim without first building the floor, and then the wall....
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Hi there, I believe it goes Wall, Floor, Foam Cove... The floor holds the wall foam in and the cove goes in last...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Yeah, that is what I figured...
    Last question, how many cans of wall foam adhesive are needed for a 27ft round pool?
    I figure at least 3, maybe 4???
    Well, just ordered 4 cans of the Gladon spray adhesive.
    I figure I will use it not only on the walls, but also for gluing the pool cove pieces to each other.
    Now, here is one question I have not seen answered anywhere else...
    Do I want to glue the cove to the wall/floor at all???
    I would almost assume you would not, since you would want it to be able to squish independently without it pulling on either the floor or the wall as it fills with water. That way nothing rips/tears or pulls out of place. I could see possibly a small section of each cove backing paper being removed, just to allow it tack to the wall to stay in place, but not so much that it wouldn't just pull away from the wall foam if it starts shifting with water pressure. My point being that you would reduce gaps, seams, etc by allowing the pieces to "float" against one another, since with the water in the liner things will compress outwards on all foam components.
    Any arguments to that logic?
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I don't think I've seen anyone glue the foam cove..... Just use the adhesive that comes with the foam cove, its more than enough to hold stuff in place...
    Jun 2014
    canada
    2
    Quote Originally Posted by laceygirl View Post
    Hi everyone! This is my first time post here & this caught my attention....We are in Canada so maybe this is only for cold climates but we have foam coving and we only used the sticky adhesive on the back side of the coving. After the first year, we noticed that the coving started to "slide up" a bit. Inside the pool there is a wee gap on the bottom that is like a hiding place for algae to grow if not cleaned out properly. Just my experience but looking back, I would most definitly use some sort of glue as well to use on the foam coving.
    Quote Originally Posted by bonste View Post
    Thanks for the reply!
    Is the "gap" you are referring to only on pools with a sand bottom?
    I could see that if you put the foam cove on top of the sand instead of below the sand.
    If it is on pools with a foam floor, then you are basically saying the foam cove needs to be glued to the foam floor as well as the foam wall.
    I have no problem doing both. I just want to make sure I am not creating other issues by gluing everything together.
    I am in SE Wisconsin, USA, so we get darn cold winters also... This last winter was just brutal, so I am hoping the foam on the walls will aid in keeping the liner from tearing...
    Jun 2014
    canada
    2
    HA! See we are newbies to this pool thing and installed it ourselves! That makes sense to us now that you say the foam cove on the foam floor....A little over kill eh?
    Goodness I cant remember if ours has a sand floor. I know we put foam on the bottom of it though....
    I think it truly looks terrible from the outside if you look at the bottom of the pool... Kinda like a buldge around the bottom of the pool the whole way around it.
    Wish we knew of this site before we installed, we could have researched alot more on installation!
    Cheers!
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    I did not use any adhesive when I put my wall foam on, and it came out perfect. I just taped it about every 10 inches at the top.
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
