Thread: help!
    Mar 2014
    Cincinnati OH
    31
    help!
    I will start off by saying I don't know what kind of pump I have (I do know I have a Hayward filter system).
    We came home tonight to one of the hoses being unattached from the pump. There is a couple inches of water currently surrounding it. We do have the plug with a gfci installed.
    I haven't been outside but my husband says the pump is not working and of course, our water level is down. He tried to turn the pump off and on but nothing happened. He doesn't want to do much else right now until the water dissipates with the electric and all (we had a big rain storm too)
    My question is: do pumps, perhaps, have a mechanism built in so that if they get hot (due to no water going thru), that they shut off?
    Could the pump have burned out?
    Could the gfci sensed the water and shut all off?
    Sorry for the lack of correct terminology..I am just hoping we don't have to get a new pump.
    Many thanks!
    Cincinnati, OH. 7th year of AG 24' pool -- 4th year using BBB method.
    24'x52" AGP. Sand filter & automatic chlorinator.
    38,251
    Re: help!
    Motors will not shut themselves off. There is an overheating sensor, but after cooling it would turn back on.
    I would certainly check the GFCI first and hope that is the issue.
    Re: help!
    The circuit breaker in the panel might be tripped. The gfci is probably tripped. If the gfci got wet, it should be replaced. If the motor got wet inside, it might be worthwhile to have it checked at a motor shop.
    Note: Don't do anything that you are not sure you can do safely.
    Support the site
    Mar 2014
    Cincinnati OH
    31
    Re: help!
    Thanks! It was the gfci. I spoke w/ the electrician who did the electrical work and bonding... Im just happy I didn't have to pay for a new pump
