Thread: Aqua Rite - How to Program Spillover
    Apr 2012
    49
    Does anybody know how to program Aqua Rite PS 8 so that the timer can run the filter in spillover mode for an hour and then run in pool only mode for the rest of the program? I can only figure out how to do one or the other in configuration menu. Thanks.
    ____________________________________________________________ ___________________
    21,000 gallon in ground rectangular plaster pool, Sta-Rite High Rate Sand Filter Model 82524-3, AO Smith SK1152 1.5HP motor w/ Sta-Rite bronze pool pump, Hayward Navigator
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Aqua Rite - How to Program Spillover
    First, I think you have an AquaLogic and not an AquaRite. They are different.
    Second, the ability came in later releases so what is your firmware version? It may not support a spillover run.
    Mark
    Apr 2012
    49
    Yes. I have AquaLogic PS8. I see 'Main Software Revision 2.66' under the Diagnostic Menu. Is that the firmware version?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Yes, that is the firmware version. Unfortunately, I don't think that version supports timed spillover. You have a choice of pool OR spillover but not both.
    Mark
    Apr 2012
    49
    That's what I suspected based on the options in the configuration menu. Thank you for confirming.
