Thread: Intex 637R + WHICH saltwater system?
    Jun 2014
    Gig Harbor, WA
    2
    Hello - my specs are below. Basically I'm looking for a few suggestions on which saltwater system I can use with my current set up. I have no intention to upgrade current pump filter at this time. Thoughts, suggestions would be great thanks!
    Pool: Intex 15'x48" above ground
    Filter/Pump: Intex 637R 1000gph
    Saltwater system: _______________??? (Amazon link, etc.)
    Thanks!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Intex 637R + WHICH saltwater system?
    The Intex system is by far the best choice for you. Others are going to cost around $1000 and probably need a filter and pump upgrade to work.
    Jun 2014
    Gig Harbor, WA
    2
    great thanks...now I just need suggestions on which saltwater system I should get. Any suggestions?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    You could also spring for at least the 635 1500 gph pump and filter. Better would be the 633 2500 gph. Both of these would require upgrading the pool wall fittings, but would put you in a better position should you decide to hard plumb your pool.
    I'm not sure, but I don't think any of the Intex SWG are compatible with the 1-1/4" clamp on hoses that go with the 637.
