Thread: Light Cord Sealing
    Light Cord Sealing
    Hi
    I replaced my light fixture and cord and want to seal up the cord light conduit at the hole in the niche. I bought some JB Weld WaterWeld epoxy putty (Home Depot). (I still have water in the pool).
    I kneaded it up and then proceeded to push it into the conduit hole...... IT WON'T STICK .....My niche (in ground plaster pool) is some kind of metal.
    What is the best brand that will stick good when applying it under water?
    thanks
    38,548
    Re: Light Cord Sealing
    That conduit is designed to be full of water, so sealing it is not required. I think they are usually brass.
    I am actually trying to find a leak and wanted to cross this off the possibility list...
    If you seal that conduit up you are going to have an extremely difficult time if you every need to replace the light fixture.
    patrick3229's Avatar
    Feb 2012
    265
    There is a product called cord stopper which is a rubber plug with 2 holes in it (one for the light cord and a second for the ground wire), this plug fits into the hole of your niche to prevent water going back into the light conduit.
    You can see this product here http://www.gandptools.com/Catalog.html
    Not sure if it is absolutely necessary, however I did replace my light fixture a few weeks ago and we had to dig up some of the conduit and it would have been nice to have these in place as the water leaking back into the pipe made it a bear to repair the conduit.
