Results 1 to 7 of 7
Thread: Ditching the "chemical package" from the retailer... What to purchase?
    Jun 2014
    Chicago, Il
    3
    Hi All,
    You guys have been extremely helpful and have given me tons of much needed advice. With all that you given me, I've decided to ditch the "package" the store was trying to sell me all together. I've done my homework on pumps and filters (thanks to you guys) and have decided on those. I now need some input on chemicals or substitutes. I've read a lot about BBB... My question to you, is what do I need to purchase day one? Should I only be purchasing those or other stuff from a pool store? I'd like to get my test kit and "chemicals" before my installation, but was wondering if there is a list or something you'd recommend. I tried searching and my apologies if this info is already out there. I'm guess I'm looking for a new owners "shopping list." Lol
    Lastly, I decided not to go with the retailers "cleaning accessory kit" either. Can you guys tell me the essentials needed to physically clean my pool? Net, vacuum etc... The kits they sell come w a crappy manual vac... Would you suggest I get a robot? Since my pool will be small (15ft) I don't want to go with anything that is overkill.
    Thanks again for all of your input! This site is sooo valuable!
    FYI... I have absolutely NO leaves in my yard. There are no trees close by.
    Have a deposit on:
    AG 15ft Round 54in/5500 gallons Wilbar Quest w/ stainless steel side panel
    Hayward SwimPro 110 Filter, Hayward SwimPro 2HP 2Spd Pump
    Vision Pro Nature Sanitizer
    Here to figure out if this package that I have on hold is sufficient...
    38,271
    Re: Ditching the "chemical package" from the retailer... What to purchase?
    Have for day one:
    - Order one of the Recommended Test Kits. The TF-100 is the best value.
    - Stabilizer (you will want 30-50ppm ... use PoolMath). Can be purchased at Walmart or hardware stores in the pool section. Look for Stabilizer=Conditioner=cyanuric acid
    - A few bottle of bleach to maintain FC levels
    After it is full, you can test the pH and TA and see if those need adjusted. Although you can get a decent idea by testing your tap water.
    Equipment
    - Pole
    - brush
    - leaf rake and/or skimmer
    - hose & manual vacuum head and/or automated cleaner (suction or electric robot)
    - Up there, you likely want a solar cover as well.
    Jun 2013
    East TN
    309
    Make sure you check the % of sodium hypochlorite on the bleach bottle before you buy it. If it dont say then it is a really low %, so just pass it up and look some more.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Have for day one:
    Equipment
    - Pole
    - brush
    this is a great list, but I would say even if you get some automated cleaner you still want a hose and vacuum head.
    Support the site
    Jun 2014
    Glendora, CA
    61
    I am in the similar boat as the original poster. For liquid chlorine, do you walk around the pool and pour them in? How much should one pour in? I am moving to a house with a pool that has been serviced by a company (was told by the agent).
    TT
    Isaac-1's Avatar
    SW Louisiana
    6,711
    How much you need depends on the size of your pool, and what your test results tell you.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Nina,
    Yeah, its me again, from your last thread. I am glad you're stepping back and having another look at what you want and need instead of what someone else is trying to push on you.
    I really feel this is the best and you will be much happier.
    Starter chemical kit is what Jason (jblizzle) recommended to start with would be an excellent starting point.
    I would only recommend to add a gallon of muriatic acid. The acid is what you use to bring the Ph down if its too high.
    Please keep asking questions too! YOu will get all the help you could imagine.
    Divin Dave,
