Thread: Aquarite readings
    Jun 2014
    Atlanta Ga.
    4
    Aquarite readings
    Had an issue with my Hayward Aquarite readings going out. Replaced oem Hayward t15 cell and registered it. Worked for a couple of days, leds went out. Replaced the Digi-Key Part Number 570-1062-ND, worked great for a few days, now the readings are
    Clor 3.7
    temp 30 (I know it's 86 degrees in pool)
    24.9 volts
    7.5 currant
    99 output ( set all the way up)
    -3.7 salt
    al-0
    rl 1.4
    Pool is clear and shows generating 2 leds lit and also switches to super chlorinate 3 leds lit. Inground 35,000 vinyl pool Aquarite is 5 years old, new t-cell (oem) this month.
    Quantab between 6.2 and 6.4. Faulty T-cell? Bad Board? Set up wrong? Thanks for the help. Joe
    38,521
    Re: Aquarite readings
    30 degrees C = 86 degrees F
    I think your settings got changed.
    Likely the salt setting is also changed to not actually be ppm.
    The first number is the average salt level, in grams per liter, not chlorine. Your unit is set to metric. To switch back, scroll to temperature, then switch from "auto" to "superchlorinate" and back to auto.
    I don't understand your reference to "quantab"?
    Your numbers look ok. The current (amps) is a little high, but otherwise, the rest seems fine.
    Do you have a heater?
    The high amps might be due to either the salt level or the water temperature being higher than the unit is reporting. I would suggest testing each independently.
    Support the site
    Jun 2014
    Atlanta Ga.
    4
    Thanks, settings got changed to Celsius somehow. Changed it back, all is good now. Quantab strips are the salt test strips I bought at Walmart. Thanks again. Joe
