Results 1 to 9 of 9
Thread: new to pools just got liner replaced
    Jun 2014
    auburn, me
    9
    I bought a foreclosed property over the winter.
    16x32 inground pool roughly 18,000 gallons, brand new liner and fill with pond water about two weeks ago. Nothing has been put in it yet except initial liquid shock to clean up the water and some bleach since.
    Just got a k-2006 test kit delivered.
    What should I be testing at this point, other then the PH which is coming out at 7.0
    I assume most of the chlorine has dissipated and there is no CYA in it?
    also the pool is plumbed as shown
    with the only return directly across from the skimmer, (another port I though was a return on the same side of the skimmer is actually plumbed as a suction line along with the skimmer on a 4 way valve)
    so the shallow end of the pool is not getting skimmed?
    Should I replumb it as a return to increase surface movement?
    16x32 Vinyl inground pool ~18,000 gallons brand new liner. PH 7.0 TA 3ppm if i did test right. K-2006 kit. Sand filter.
    Jun 2014
    auburn, me
    9
    Re: new to pools just got liner replaced
    Update:
    Tested PH and it is about 7.0
    Tested Ta and it appear to be about 3 ppm?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,492
    WELCOME! You are doing a great job so far! You bought a good test kit and you are asking questions! SWEET!
    Get some chlorine/bleach in it TODAY as in NOW!
    Have some chlorine on hand to keep FC in it at all times. Shop around to see where your best price is.
    While you are getting some extra chlorine get some CYA/stabilizer to put in it today as well. Use a sock tied to a brick in front of the return. You can/should give it a squeeze every once in a while to speed it up.
    When adding your chlorine add as much as if you have met your CYA goal even though the CYA will not show up on the test until about a week after you put it in.
    To get your PH up you can buy some PH up or you can angle your return so it aerates the water good. That will cause it to go up.
    TA-needs to go up as well. It works with the PH. Read pool school for this one as I have not had to work on mine so do not know....
    Once you have added chlorine, CYA, and brought your PH up you need to read and read and read pool school
    You are on the right track with everything you are doing. Keep it up!
    Kim
    Jun 2014
    auburn, me
    9
    alrighty pb pool math I should target a ph of 7.5?
    looks like I need to add 187 oz liquid CYA to bring to 30? I assume it should actually be at 0 as it is from a lake, or should I test it?
    Water is crystal clear other then some surface bubbles, do I need to start with the SLAM process?
    Jul 2012
    Tallahassee, FL
    30,492
    You are on the right track. I will tell you that liquid CYA is $$$$ compared to dry BUT it will not need the time to get dissolved as the solid so...
    PH of 7.5 is a good place to start.
    I would not think there is any CYA in pond water.
    SLAM??? Try this for me. Read about the Overnight Chlorine Loss Test. http://www.troublefreepool.com/conte...loss-test-oclt Do this. Do you pass it? If so no slam is needed. If not....SLAM time.
    Kim
    Jun 2014
    auburn, me
    9
    alrighty added enough shock to according to the calc bring it up to FC 4, will test in a couple hours, and have powdered CYA in a sock by the return.
    Jul 2012
    Tallahassee, FL
    30,492
    shock? What shock are you using? You should only be using chlorine or bleach to raise your FC.
    Kim
    Jun 2014
    auburn, me
    9
    12.5% liquid, same price as bleach for 50% more active ingredient at Job lot right now
    Jul 2012
    Tallahassee, FL
    30,492
    12.5% is a great %
    The highest I have found around here is 11% It is right up the road at ACE Hardware. I just have to make sure to take the truck instead of the car. LOL
    Kim
