Results 1 to 7 of 7
Thread: Dirty pool
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Dirty pool
    I have a situation that I think is a bit odd.
    Yesterday afternoon I vacuumed the pool, then changed out the cart. We had a quick heavy rain (1/2" rain) early this morning. When I checked the pool it was a little bit cloudy, so I turned the filter pump on. Came back an hour later, and pool is now clear again, but looked like I hadn't vacuumed. all the dirt had settled to the bottom, like circulating the water had caused it to fall out of suspension. Fresh filter not that dirty, but obviously had caught a lot of crud from the water.
    Question is, does anyone else see this happening in their pools?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Dirty pool
    I suppose you'd like to see some numbers for my water, to rule out chemistry.
    FC -- 5 I keep it between 4 and 8. Yes a little high. Compensates for the dogs swimming.
    CC -- 0 (barely pink, 1/2 drop or less would clear it, 10mL sample)
    pH -- 7.4 rock steady until I have to add water.
    TA -- 80
    CH -- 100 -180 indeterminate end point problem
    CYA -- 35ish, between 30 and 40
    Went back to Pool School, Extended tests. CH 90 by that method.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Dirty pool
    Yep...........every dadgum time it rains! Rain equals water molecule wrapped around a dust particle or something else.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Dirty pool
    But why would (I'm guessing) 1/2 of the dust settle after the pump is turned on? Is it similar in action to the cyclone dust separators? Round pool, with a 3" slope to the center. Surely that wouldn't be enough of a slope to cause that. The coating of dust appears to be fairly evenly distributed throughout the pool. You can clearly see every doggone wrinkle and divot in the pool floor.
    Re: Dirty pool
    The same thing is happening to me lately...though, again, it does seem like it is raining every other day here. I just wouldn't think the rain is causing the dirt.
    With the pump, I notice that the "dirt" or watever it is seems to accumulate more on the side of my pool AWAY from the return jet, so is it possible that when the pump is on it tends to push the dirt to one side (the side opposite the return jet) where it then accumluates?....like you, I seem to think that if the dirt was spread around the water somewhat evenly that you would not notice accumulations of dirt in certain spots. The amount of dirt I see seems to be inversely proportional to the distance from the return jet.
    24 ft. above ground pool, 13,500 gallons, installed summer 2013
    Cartridge Filter, Hayward 1.5 HP Power-Flo LX pump
    Main drain
    5 happy swimming children
    NW Indiana
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Dirty pool
    If you have a cover, is there dirt/dust/ pollen on it when you leave it for a few days? Mine, yes, definitely. We live near a highway, and also, pollen has been terrible the past few weeks.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Dirty pool
    Any flat surface gets a coating of dust after a few days here.
