Thread: Sand in return to pool for first 10 seconds after pump turns on
    Jun 2014
    Wind gap,pa
    1
    hello,
    I have a Hayward S180T filter. I just replaced the sand this year and I noticed that sand will come out of my return line into the pool but only happens for 10 seconds or so then there is now more sand. This happens when ever the filter is turned on. what could cause this to happen?.... it happens after I backwash as well even after I rinse for 1 minute. Would a cracked lateral cause this or would that be constantly sending sand into the return?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Sand in return to pool for first 10 seconds after pump turns on
    Hi, welcome to TFP! Have you looked at the spider gasket? A worn spider gasket on the multi-port valve can allow some sand into the pool. If the spider gasket is ok, then you will need to remove the sand and check the laterals. It is possible there may have been some damage when you replaced the sand.
    Love TFP? Become a
    TFP Supporter!
