Thread: installing SWG with VS pump
    Jun 2014
    Tehachapi CA
    8
    I have new pool with a Nexa Pure SWG and an Intelliflo VS pump. The Nexa Pure is designed to sense that the pump running when it senses the load to the pump through a timer or relay. Since the VS pump is always connected, the Nexa Pure does not know to shut down with the pump is off. When the pump is shut down, the Nexa Pure indicates the lack of flow and is probably not running. I would feel better if the the SWG would go into standby like it is supposed to. This is probably another case of sticking with the same manufacturer for all components. My components came in a kit. Any ideas? Thanks.
    20,000 inground with spa, Intelliflo pump, Nexa Pure SWG, Hayward OnCommand not yet hooked up (probably going to switch to a Pentair controller)
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Re: installing SWG with VS pump
    Quote Originally Posted by teares View Post
    So is your Nexa Pure sensing pump load?
    It's not necessarily true. I have Pentair VS + Intellichlor IC40 and facing the same problems: how to sense actual pump load instead of just flow sensing. However, flow sensing is OK.
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    38,271
    To sense the load, you have to use a current sensing relay to switch the power to the SWG on/off ... you should be able to find info searching the forum.
    Ukie's Avatar
    May 2012
    Export, PA
    83
