Results 1 to 8 of 8
Thread: Is my Hayward heater supposed to be this noisy?
    Apr 2013
    Battle Creek, MI
    298
    We love the new Hayward H100ID1 natural-gas heater, but it seems to make a lot of noise, and after about two weeks it hasn't gone away. I can't tell if it sounds more like a whiny, squeaky fan bearing or if it's associated with the boiler/burner process, but it doesn't sound right. Should I be worried about this or does everyone's heater sound like this and I should just live with it?
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Is my Hayward heater supposed to be this noisy?
    If it's a whining sound, then you have water flow issues. Not enough water is going through the heater. Make sure you have good water flow through the unit and into the pool. If it sounds like a banging or gravel sound, then it's a broken bypass in the heater.
    If this unit is band new, call and get a service tech out to look at it since it is under warranty.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by ps0303 View Post
    I have a 3,000 gal/hr pump completely diverted through the heater. Low flow doesn't seem likely to me. This was a DIY install, purchased through eBay.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Hmmm. So it's defiantly a whining/groaning noise?
    Paul
    Jun 2012
    western NY
    1,559
    Mine does the same thing. Kind of like a haunted house kind of moan. does not do it all the time but, does do it
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Apr 2013
    Battle Creek, MI
    298
    Definitely a high-pitched whine, somewhere between a mechanical sound and a sort-of venturi-like whistling sound. When it first starts up, you can hear the blower (I assume it's a blower) and the combustion sounds, and then it just escalates from there, leaving me not sure what the source is. And it does come and go, like danpik said. I guess I'll try paying particular attention to my pressure and water flow, as right now my D.E. filter probably needs a good flushing and I'm bumping it practically every day. It's been a very debris-filled May and June!
    Apr 2013
    Battle Creek, MI
    298
    Well, I believe I have to give the early nod to ps0303. I did some extensive monitoring of my filter, which needs a good flushing, and the heater, and I think he might be right -- although, for a device rated at 20-70 GPH, I find it hard to believe my filter is falling below that very often. Anyway, I will get the filter flushed and maintain good flow for a while and hope that solves the problem.
    Now if I could just get it to stop raining so that I can get all of this work done!
    Apr 2013
    Battle Creek, MI
    298
    Final update: I broke down and flushed the filter and recharged with Fiber Clear, and although it seems like the pump/filter is running at about the same pressure as before, the flow is holding consistently and the heater has not made any screeching/squealing noises all day. Thanks for the help!
