Thread: Sanitizer Setting on Intellichlor Chlorine Generator with Solar Blanket Installed
    May 2014
    Rogers, AR
    8
    Hi - New to TFP...
    Second year with Saltwater Pool, and decided to use a Solar Blanket this summer to help keep water temp more comfortable.
    Last year, I could set IC-40 at 60% output and chlorine levels were perfect all summer.
    This year, high Chlorine levels (ie: 5 - 10 ppm) despite adjusting output down to 20 or 40%.
    Any directional recommendations on Sanitizer Settings while using a Solar Cover/Blanket?
    Thanks!
    Northwest Arkansas
    15K Viking Fiberglass - Salt Water - Pentair Intellichlor IC40 SWG
    1 hp Whisper Flow Pump w/Triton II TR60 Sand Filter
    Pentair MasterTemp 125K BTU Natural Gas Heater
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Sanitizer Setting on Intellichlor Chlorine Generator with Solar Blanket Installed
    Welcome to TFP!
    I'm surprised you are seeing such a difference. What is your current CYA level and how does that compare to last summer?
    May 2014
    Rogers, AR
    8
    I keep detailed records.... easy to answer!
    Last year .... same timeframe CYA was in the 20s
    This year, CYA has been a bit high - in 80's; however most recent test put it about 50.
    One concern - Have you ever heard of a Intellichlor Unit malfunction by OVER chlorinating? The unit is about 3 - 4 years old. I inherited with the house we bought last spring. It still has serviceable hours left on it, but I have been battling high chlorine levels this year even prior to using solar cover.
    Thanks again!
    Northwest Arkansas
    SW Indiana
    9,199
    Well, Pentair recommends 50-80ppm CYA for the Intellichlor, so you were losing a lot of chlorine to the sun last year. Your IC40 is designed to handle pools up to 40,000 gallons, so you were working it hard last year, but because it is oversized it could handle it. This year your CYA has been more reasonable, so you should throttle it way down to maintain appropriate levels. Note the appropriate chlorine levels in the Chlorine CYA Chart
    May 2014
    Rogers, AR
    8
    John - Thanks, you are right. I have been trying my best to learn the right levels and dial it in.
    Every printout I would get from local pool store would recommend CYA level of 20 -50.... Also, I had learned some time ago that IC 40 was oversized for the pool. Again, I found out that LPS sold it to previous owners.... The good news is!!!! I can throttle back output this year to 20% (instead of 60%) and work it a lot less!!!! Makes sense!!!!
    Other things I learned .... LPS tried to recommend a 350K BTU heater for this pool! I opted to go my own route based on research and settled on the 125K BTU unit! BIG SAVINGS upfront...
    Anyway.... THANKS!!!! This website has been a great resource!
    Northwest Arkansas
