Results 1 to 8 of 8
Thread: Dirty Chlorine Cylinder - TF100
    connie249's Avatar
    Mar 2014
    Stevensville, MD
    5
    I have been doing a lot of testing while slamming my pool. Now I have a tacky hazy residue on my chlorine cylinder and my blue spoons are black(bowl area). I find this weird since I am very careful to rinse before and after every test.
    I would like to clean the chlorine cylinder and spoons. I fear that the build up may start effecting the results slightly, if it continues. Simple water and paper towels do not work, it is too tacky.
    Thanks!
    Connie
    20K gallon, inground plaster, Haward DE -(48ft2/50psi/96gpm), motor 1.5hp, built 1990's?
    38,546
    Re: Dirty Chlorine Cylinder - TF100
    Try a little muriatic acid in the cylinder. The spoon does not matter.
    connie249's Avatar
    Mar 2014
    Stevensville, MD
    5
    Will do, Thanks!
    Connie
    30,432
    The acid will work fine. Your use of the word "tacky" makes me think there is some built up residue....that's not normal.
    Cylinder (and/or spoon) should be RINSED and then shaken out and put back in the kit. All I ever get is a charcoal-like coating that is thin....like maybe a thin coat of paint and it comes off easily with muriatic and water....about 2 parts water and 1 part muriatic.
    38,546
    You rinse your spoon? I just keep it dry
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    <<<<<<<has never rinsed the spoon. I just scrape it off on ocassion.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Rinsing your cylinder with RO or distiller water helps keep glassware cleaner longer. Still. A bath in MA as mentioned should be routine for everyone at least once a summer. You can't do it too often so it's up to you.
    Essential Links:
    connie249's Avatar
    Mar 2014
    Stevensville, MD
    5
    I have never rinsed the spoon. But I will try using the diluted ma to clean it. I will also keep some distilled water on hand for maintenance.
    Connie
