Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: 0 fc, 0 cya, 0 ta
    0 fc, 0 cya, 0 ta
    First, who (or where) sells the TF-100 test kit?
    Second, the test strips I have show:
    0 FC
    6.4 pH
    0 TA
    100 TH
    0 CYA
    I've read so much on the Pool Math (and other posts) my head is spinning....What to do about these numbers? The pool water looks fine, but I know these numbers can't be good...I add trichlor granular every day too...
    24k Gal, IG Plaster(I think), Hayward EC-65 DE filter , 1 speed US Motors pump, rusted coping with splintering wood covering (eewwww)...its Upstate NY, after all...Taylor K-2006 test kit...Pool is 40+ years old
    38,319
    Re: 0 fc, 0 cya, 0 ta
    TF-100 is sold by tftestkits.net ... there is also a west coast distributor (poolsupplyworld.com) if you live in the West. Please add your location to your profile as described HERE as it will help us help you.
    I would put no faith in any results from test strips.
    If you are adding trichlor, there is NO WAY you have zero CYA. That could explain the low pH and TA (if those are to be believed).
    I'm in Upstate NY...and the granular chlorine i use is the stuff from HD...item # 22119PTM...hope this helps...
    38,319
    The product does not look good ... seems to have a whole bunch of random ingredients in it.
    That is trichlor so it adding a lot of CYA to the pool, plus boron salt? and 15-25% mystery ingredient. No way I would use it in my pool. http://www.homedepot.com/catalog/pdf...ba7a308fce.pdf
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    I would stop the trichlor and start bleach. As your numbers are from strips, I don't believe them, especially the CYA.
    Support the site
    So if the stuff from HD "does not look good", jblizzle, what should i use? besides liquid chlorine/bleach, of course...
    I dont want to keep running out and getting chlorine bottles all the time...that's why i used pucks and granules...
    38,319
    Well, the only form of chlorine without side-effects (adding either CYA or CH) is liquid chlorine. That is what likely 75% of the members here use. Another 20+% use a SWG and there are a few that try to get by with the solid forms of chlorine and have resigned themselves to have to drain the pool.
    Given your location and short swim season, if you drain a good portion of the pool every year, then you may get by with trichlor, but you better have a good test kit and track the rising CYA so that you can keep adequate FC in the pool. The required FC is a function of the CYA as seen in the FC/CYA Chart. And if your FC is too low, you will have no choice but to supplement with bleach.
    The TFPC method is really just about understanding your pool’s chemistry and through accurate testing, adding only what the pool NEEDS, not necessarily sepcific chemicals. But, another thing we teach is to not add anything that you do not know the ingredients or what it will do to your pool. That stuff is 25% mystery ingredients
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    If the list of ingredients has "trade secret" anywhere in it, I don't put it in my pool! Unless the manufacturer is willing to be honest about what is in their goods, I don't deal with them.
    As an example, HTH brand AKA Arch Chemical, has several lines of goods to be sold by different retail chains. Those items sold by Walmart sometimes have "trade secret" in the list, yet the same item sold in Ace Hardware lists all the ingredients by name. I suspect it's the exact same product, with slight changes to the packaging for the target consumer.
    Long story short, what we teach here is simply know your pool, and know what, when, and why of what it needs.
    Butterfly's Avatar
    South Carolina
    10,045
    There is also lithium hypochlorite, but it is expensive.
    You're done SLAMing when:
    Ok, here's the numbers from Taylor K2006 test kit i just got:
    CC 3
    FC 8.5
    CYA 150
    TA 0
    CH 60
    pH way below 7 , it took 35 drops (at least) before it got into the 7.5 pH color
    Now what? (besides get some liquid chlorine)...i need to know what chemicals to buy (and how much to put in) to get these numbers to good levels.
    Raise your PH right away. PH that low will damage the pool. Once the PH is at least 7.0 test the TA and see if it needs adjusting (it probably won't but you never know).
    but what product do i use? and how much?
    Borax would be best, but soda ash/washing soda/PH Up is also acceptable if it is easier to find. It will take a number of boxes/pails of either one. Unfortunately, the exact amount is difficult to calculate. I suggest starting with three or four boxes of borax or about 8 lbs of soda ash, giving it half an hour to mix in, test the PH and as long as it remains below 7.2 continue one box of borax or 3 lbs of soda ash at a time. Quantities are assuming 24,000 gallons.
    Ok, i just dumped in 14 lbs. of pH up...was that too much?
    That might have been a bit much. Give it an hour to mix into the water with the pump running and measure the PH again to see how things turned out. If you can get the PH to anywhere from 7.0 to 7.8 you are fine for now.
    38,319
    One of the tenets of TFPC is to not blindly add chemicals, but to base additions on test results. Not sure why you ignored what Jason recommended and what PoolMath would show ...
    lol I added wrong, i thought i'd put in 10 lbs, but when i added it up, it was 14...my apologies....
    May 2014
    Franklin, NC
    9,187
    Quote Originally Posted by nupoolboy View Post
    no apologies necessary, we all make mistakes. Just remember, when adding anything to the pool, always add too little. You can always add more, but correcting an overshoot can be more difficult.
    Support the site
    so even after all that "pH up", its STILL sits at less than 7. According to the Taylor table in the back of their instruction manual, after counting the drops, etc...i have to add another 8 lbs of pH up...and that's to get it between 7.2 to 7.8
  20. Back To Top    #20
    May 2014
    Franklin, NC
    9,187
    did the TA come up with the pH?
    Plug your current numbers in Pool Math(link above also)
    You will save money by using the generic alternatives suggested here over commercial products like packaged pH Up.
    Support the site
