Thread: New to Forum not to pool
    Mwolf5141's Avatar
    Jun 2014
    Manchester/MD
    1
    We have had our 24ft round AG Pool for ~7 years now never had any real trouble with water quality or clarity before now. Winter cover developed a hole sometime during witer months that went undetected until removal.
    Water has been white milky/cloudy since I opened it June 1.
    Current readings:
    FC 0
    CC 0
    pH 7.4
    TA 60
    CYA 45
    Have been trying to slam it for the past week and have seen little to no improvement - I have added over 20 gallons of 8% bleach and have kept 3" slow dissolve pucks in my strainer.
    What am I doing wrong?
    13,500 gallons
    24 foot round
    AG
    Cannister Filter
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New to Forum not to pool
    Welcome to TFP
    What test kit are you using?
    I suggest you go ahead now and add about 20 FC bleach/liquid chlorine. Wait about 30 minutes, pump running, and retest FC and CC. Post #'s here in this thead for us.
    Are you following the SLAM process from Pool School to a T? What FC SLAM level have you been using?
    Can you post a pic of the pool?
    What is CH level?
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Welcome!
    I would wonder if there isn't a lot of organic debris hiding beneath the cloudy water. Have you tried dragging the bottom with a leaf rake? Vacuumed blind?
