Results 1 to 12 of 12
Thread: SWG and CYA??
    May 2014
    Westport, MA
    28
    SWG and CYA??
    So I am about to install my SWG (Aqua rite pro T-15). I added about 500 lbs of salt to my pool....
    Water is clear, and the chemistry appears right.
    FC- 2.88
    TC- 2.93
    PH-7.9
    CYA- 49 (Stabilizer??)
    TA- 104
    Cal- 190
    Salt 3240 ppm
    My question is that the CYA when using a SWG is supposed to be higher than when using chlorine (I think)...
    So should I try to get the CYA up to the 70-80, or will the SWG take care of that once it is up and running?
    If not how should I get it to increase....? I am assuming that CYA is stabilizer also...
    Thanks
    18X36 inground with vinyl liner.. Hayward DE .... Upgraded to Hayward Ecostar
    26,700 gallons....
    38,371
    Re: SWG and CYA??
    How did your get those test results? They are clearly not from one of the Recommended Test Kits.
    CYA = stabilizer = conditioner = cyanuric acid
    The SWG will not raise it, you have to add it. BUT, I am not sure I would add it based on those test results which may be wildly off.
    May 2014
    Westport, MA
    28
    Re: SWG and CYA??
    Got the water tested at my local pool store..... They installed the pool when new....
    Why would the test results be wildly off??
    Thanks
    26,700 gallons....
    Re: SWG and CYA??
    You would be shocked how often pool store tests are wildly off. CYA is the most likely number to be way off.
    May 2014
    Westport, MA
    28
    Re: SWG and CYA??
    How should I verify the values??
    26,700 gallons....
    38,371
    Re: SWG and CYA??
    Get one of the Recommended Test Kits.
    May 2014
    Westport, MA
    28
    Re: SWG and CYA??
    Which one should i get and where??
    26,700 gallons....
    Jul 2011
    phoenix
    133
    Re: SWG and CYA??
    As others mentioned get a kit and get familiar with it. Did you see how they performed the tests? Reason I ask is the ta being 104 strikes me as odd. Every pool store I used does a drop test that you then multiply by ten.
    I recently installed a a swg myself and was in your shoes. Use their numbers as a ballpark idea but trust your own results. My cya was 100 according to the pool store but when I did my own extended tests I ended with much higher and drained part of my pool before the install.
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    38,371
    Re: SWG and CYA??
    Well, if you want to be told directly, order the TF-100 from tftestkits.net ... the SpeedStir is a great add-on as well.
    May 2014
    Westport, MA
    28
    Re: SWG and CYA??
    The pool store used an automatic test that uses a computer..... not sure what type of test it was..... no strip or adding drops to the water at all...
    26,700 gallons....
    38,371
    Re: SWG and CYA??
    Do you know when it was last calibrated? Do you know if the user has been trained with the machine properly?
    If not, how can you believe anything it spits out? Digital testers always reminds me of this cartoon:
    Jun 2014
    Houston, Texas
    475
    Re: SWG and CYA??
    When my time comes, I will need to be told too. I looked at it and scratched my head. I had No idea this process was so complicated!
