Algae/Main Drain
I had the SLAM Question/Confession post over the last 2 weeks.
Started a SLAM on 6/23 after a vacation and "passed" the SLAM by the end of the week (the only lingering question being that the deep-end water wasn't perfect--it was clear, but not perfect, but I was continuing to pass the chemical tests). I know crystal clear water is requirement #3. As I noted on that thread, I kept noticing brown deposits each morning, at the end of the SLAM and after the water was nice and blue. When I leaf-vac'd the deep, the minimal stuff I pulled-up was quite gritty like sand--it was sand, in fact. When I try to get it up with my fingers, it's too fine. It definitely dusts-up when I brush it--looks like little dead algae clouds along the floor. The brown stuff is on the angled portions of the walls in the deep and on the floor of the shallow and along the seams. I feel like I'm brushing dead algae. I brush it each day from the shallow floor to the deep. The shallow looks great afterwards, the deep clouds-up a bit, and then it settles back to being pretty clear, but not perfect (maybe not quite as clear over the last 2 days, though--there's a bit of a worsening). I assumed at the end of the SLAM on 6/30 that I needed a deep clean on the filter (but haven't done one yet) and stopped the SLAM.
Anyway, the shallow is nice and blue and clear like I prefer, but the deep is starting to get cloudy again, particularly, of course, when I sweep the brown stuff to the main drain.
I did an FC/CC test just now, and it was 3.5 FC and .5 CC. It was 5 at the end of yesterday and I didn't add anything.
CYA is up to 40 from 20 since I threw a bag of trichlor shock and a trichlor puck in the skimmer on Saturday (wanting the CYA to climb a bit, and I have some bags and pucks to burn through).
Added 57 oz of 8.25% tonight to get the 3.5 to 5.
Three questions:
1. Does it sound like I have a relatively controlled algae outbreak--it's been like this a few days but isn't really getting worse--or is it possibly sand from the filter that needs to be deep-cleaned? Struggling to distinguish between the 2 since the shallow end looks good and the deep is cloudy, and given that I did notice today, with my fingers in the shallow, that some of the residue is gritty like sand.
2. I noticed today that my main drain has virtually no suction when the skimmer and the main drain are wide open. It has very slight suction when I close off the skimmer line. Should I have noticeable suction in the main drain? Could it be clogged or not working properly, such that the deep-end is not filtering, hence the slight cloudiness and lingering debris?
3. I have a "chlorinator" on my pool pump. There's nothing in it. I noticed during my SLAM that water was leaking out of the top of it pretty steadily. I opened it up, confirmed there was no chlorine in it, and figured that it should be "off" if I am not using it. That appears to have stopped the water leaking out of it. Should it be off when there's nothing in it?
Thanks as usual.
