Thread: ring around the pool
    Oct 2007
    Lafayette, La
    39
    I have a 15000 gal fiberglas pool. I noticed a ring around the water line that does not just wipe off. I vaguely remember reading something about ph level and chlorine level causing such a ring. Does anyone know what I am talking about and is it high ph and lower chlorine level? Yesterdays readings were FC- 3; CC-0; TC-3; ph 7.6-7.8 (color variation kills me) TA 80; CYA-50; TCAL- 240 water temp 86. Otherwise my pool is clear blue and beautiful.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: ring around the pool
    Try a Mr. Clean magic eraser, test in an inconspicious (sp?) area first. supposed to be safe on fiberglass.... is the "ring" like a stain, or a scaly residue? What color would you describe it?
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    the majic eraser is godsend. my FG steps had quite a ring on them, a couple mins with the eraser and it was brilliant white again. I then got on my floatie and went around the tile line (vinyl) it brought it right back up.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Jul 2007
    Waterford Michigan
    36
    Molso is that safe for Vynial? I'd like to try it but I'm not sure.
    15x30 AG
    Cartridge Filter
    Solar Heater
    1.0 HP 2 Speed pump
    + 2 KIDS
    The Magic Eraser is slightly abrasive. Used appropriately it is fine but if you start really scrubbing you can scratch the vinyl. When it works, it works with only a little effort and scratching is not an issue.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Yes, I didn't scrub hard, just a very wet rub. (If that makes sense) but I didn't need much effort, it cleaned right up.
