Results 1 to 7 of 7
Thread: Best way to heat 24' AG Pool Cover in day?
    ddpool's Avatar
    Jul 2008
    Minnesota
    61
    I am new to this and just had a 24' AG Pool installed. I have a solar cover. Do I leave it on during a hot sunny day? Will this help heat the water? Also, how about putting black tubes under cover? Any suggestions on the BEST way to heat an above ground pool? Thanks.
    Coming Soon: In-Ground
    Previous: 24' Round AGP, 2HP Pump, Sand Filter, Solar Cover
    Re: Best way to heat 24' AG Pool Cover in day?
    Welcome to TFP!
    Having the cover on at night makes a big difference. Using a cover during the day is much less important, unless you are in an area with very high evaporation rates.
    ddpool's Avatar
    Jul 2008
    Minnesota
    61
    This is a great forum! Thanks for the tip! It is a newer style Diamond blue on top and silver underneath. Their websites states it actually heats the water? But I hear so many different views. Does anyone have any tricks that they have used that actually heats the water. I am in Minnesota and need all the warm water I can get.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    We had one, it defintely helps the water temp, we have a cheapy one now. In July, if we get a run of the hot days, 90 + if I left the cover on, the water would be too hot. Probably because the warm nights too, and the cover on traps all that heat....so if I leave the cover off for a night, it drops to a more comfortable 88. I keep my cover on during the day when the pool is not in use. Cuts down on chlorine loss to UV rays, and prevents evaporation.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Quote Originally Posted by ddpool
    I'm going to have to say Solar is the way to go! I think it has the lowest cost for start-up, and it's FREE to run, except for the electric to run the pump. I got one panel from a pool store locally for $139.00 last summer, then this summer, got 2 more off eBay for $160.00 Shipped to my house. I have just over $400.00 invested in mine with $100.00 in plumbing/PVC. The plumbing cost so much because I moved the filter 25 ft from the pool and put the panels on the roof.
    The three panels will raise my water temp. 8-10* on a full sunny day, running from 9 a.m. to 6 p.m.. Also, I leave my solar cover on all the time except when we're in the pool. It makes a big difference at night, especially with cool nights. With it, I lose 2-3*, without, maybe 6-8* on a cool night.
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    I live in MN as well and use a solar heater and a solar blanket. I really don't think the solar blanket heats it very much, but it dose hold heat in at night. I've been holding a temp around 88 all summer.
    16' by 32' cornelius AG vinyl liner, 6' deep end, 14500 gal.
    Hayward 250 Lb sand filter
    Hayward 40 GPM pump
    2-2' by 20' sun grabber solar heater.
    4 gal Liquidator. BBB
    ddpool's Avatar
    Jul 2008
    Minnesota
    61
    I thought I would post my "cover on 1st part of day" method. We leave solar cover on till around 1pm and within 2 days I am now up to 85degrees and holding. So, at least with my solar cover (blue on top/silver bottom) if left on in the sun...your pool will heat up. I will keep you updated if things change...but for now....solar cover on when not using seems to be working and definately heats up the pool.
