Results 1 to 18 of 18
Thread: New Pool Bid - how does it look?
    Aug 2013
    Houston, Tx
    94
    We have received a bid from a pool builder we will most likely go with. I would appreciate it if some of you pool veterans could look at this and tell me if there are any glaring omissions or things we haven't thought of but should. The one thing that caught my eye at first glance was there was only one pool light. Is it worth it or necessary to add a second? Eager to hear your feedback on all!
    Pool Shape: Custom
    Pool Perimeter: 109 LF
    Pool Area:615 Sq. Ft.
    Max Length 34 Feet
    Max Width 18.8 Feet
    Pool Minimum Depth 3 Feet
    Pool Maximum Depth 6 Feet
    Approximate Gallons 20,756 Gallons
    Spa 40 sq. ft. Raised 18 inches
    Structural Specifications:
    Excavation: BOBCAT dig/ Home owner to determine access.
    Steel Schedule: 4 x 1/2" Box Beam, pool cage to be 3/8"x 10" O.C.B.W.
    Pool Structure: Beam to be a 12" box
    Pool walls minimum 6"
    Pool floors minimum 6"
    Coves minimum 8"
    Deck dowels to connect pool to decking
    Equipment Specifications:
    Pool Filter 430 Cartridge with Spa
    Filter Pump 2.7 HP VS Pump
    Feature Pump 2 HP
    Pool Cleaner In Floor
    Sanitizer(s) Rainbow 320 Chlorinator and Ozone Joe Ozonator
    Heater Hayward 400.000 BTU Heater
    Pool Lights 1 Hayward LED Pool Light(s)
    Air Blower 1.5 HP Polaris QT Blower
    Warranties
    Equipment 3 Year Warranty on Equipment
    Gunite Warranty Lifetime Structural Warranty
    Craftsmanship Warranty 1 Year Warranty on all pool workmanship
    Mechanical Specifications:
    Skimmers 2 Hayward
    Pool Returns 4 1.5" Schedule 40 PVC
    Pool Main Drains 2 Anti Entrapment, VGB Compliant
    Spa Main Drains 2 Anti Entrapment, VGB Compliant
    Pool, Lights and Equipment to be wired persuant to current NEC code.
    Sub Panel Included No
    Pool Coping, Decking and Drainage:
    Coping Material Natural Stone Travertine, Slate, Quartzite, Leuders
    Waterline Tile Standard Ceramic
    Deck Size/ Material 1330 Sq.Ft. of Stamped Concrete (400 sq.ft.min)
    4" Drainage 75 LF
    Deck-O-Drain 0 LF
    Overflow Line Yes
    Fill Line Auto with Vacuum Breaker
    Pool Interior
    Swimming Pool Interior: Wet Edge Pearl or Satin
    Prism for Spa only
    Pool Controller
    Automation: PDA Prologic PS-8 - Pool Spa
    Additional Items
    Raised Beams 16 ft of 12 inch raised beam and 15 ft of 18 inch raised beam with ledge stone facing
    Pool Entry: Tanning Ledge Per plan with dual bubblers
    Benches: Per Plan
    ETA: I just realized that our bp has a chlorinator listed when we want a SWG. Will update again once that is changed.
    21k gal IG, SWG, WetEdge Satin Matrix Antigua in pool, Primera Stone Tahoe Coast in spa, 430 sq ft cartridge filter, 2.7 HP variable speed pump, infloor cleaner
    Our build:
    http://www.troublefreepool.com/threa...c-Houston-pool
    Re: New Pool Bid - how does it look?
    That looks nice.
    I would skip the ozone system. They add very little value and is another thing that needs occasional maintenance.
    In-floor cleaning has pros and cons. They use more electricity and tend to be expensive to maintain in the long run, on the other hand they are great at keeping the pool clean especially if you have a lot of blown in dust.
    jimmerz's Avatar
    Jun 2012
    Pittsburgh, PA
    169
    Looks great! without being rude, could I ask what this will cost? I really like that layout and I am going to show my wife. We are planning an in ground pool in the near future...(5 years maybe). How many jets are in your spa?
    24' x 54" Oceanic Round AGP, 1090 Hayward Skimmer, EC-40 Filter system, Automatic Chlorinator. Pool will be in Full sun for most of the day (9am-6pm).
    Aug 2013
    Houston, Tx
    94
    Jason, thanks for your input. What's your feeling on the pool light? Is one adequate?
    jimmerz, thanks for your compliment! We went through a lot of pool pictures on Houzz and here to basically end up with a rectangular pool, lol. The pool is going to be around $85k, verified with two different PBs quoting the same price. I dont know how many jets are in the spa. I guess that's a good question to ask my PB.
    Our build:
    For a pool that size, I would put two lights in the pool and a third in the spa. However, it really depends on what kind of effect you are after. One light is more than enough to be able to see to swim. Having several lights is about esthetics.
    Jun 2014
    SoCal, Ca
    80
    I don't have a pool yet, but am having a 16x32 pool built and we have 3 led lights in the pool, one in the spa.
    teknic88's Avatar
    Jun 2014
    LAS VEGAS
    140
    I would go with least two lights
    21.5K gallons... 65' x 9' Shotcrete Inground Lap Pool... 3'.5" to 6.5" Depth...9' by 7" Wet Deck... Hayward all the way... 2 L.E.D lights...Pebble Sheen Aqua Blue...And above all....LOVING IT!!!!!!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Hi April,
    the SWG is a good choice over the ozone thing and the inline chlorinator. You will really like the Saltwater set up.
    One thing I noticed. The PB is not including an Electrical Sub Panel. How does he intend to power up the equipment? Is he leaving it up to you to hire an electrical contractor to install one?
    Divin Dave,
    Aug 2013
    Houston, Tx
    94
    Good question Dave. I noticed that as I was going through each line. I'm going to shoot him an email and find out.
    Our build:
    Aug 2013
    Houston, Tx
    94
    Well you have all brought up great points, and my PB says he is impressed with my questions So, he knew we wanted a SWG, just a typo. We will have two lights in the pool and one in the spa. The spa will have 8 jets. Divin Dave, he said the controller has a built-in sub panel. We are tweaking the design of the pool slightly, making a complete rectangle and extending the bench all the way to the stairs.
    Our build:
    May 2013
    Fort Lauderdale, FL
    423
    More lights! Make sure they are the big "pool sized" ones in the pool, not a dinky "spa light" like I'm stuck with
    Why two bottom returns in each side?
    Yes to SWG and the big heater will be nice too.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Aug 2013
    Houston, Tx
    94
    Zimm, his bid states Hayward LED Pool Light(s) - I take that to mean it should be a real pool light? I think of LED lights being smaller anyway but hopefully enough to illuminate the pool. For returns, I see "Pool Returns 4 1.5" Schedule 40 PVC". Where does it say bottom returns? And should there be more/less?
    Our build:
    May 2013
    Fort Lauderdale, FL
    423
    Just make sure the Hayward LED's are the "pool" and not "spa" size in the main pool. My pool has a single spa sized light and I think if I go LED in it, it won't light the pool up enough.
    I'm just curious why there are two main drains. I'm no expert on pool builds, but most pools seem to have 1.
    from your list: Pool Main Drains 2 Anti Entrapment, VGB Compliant
    Aug 2013
    Houston, Tx
    94
    Hmm, good question. I wonder if it is has something to do with the in-floor cleaning system? I don't think the size of the pool is so big it would require another (if that even factors in).
    Our build:
    May 2014
    Lewisville, TX
    29
    Recommend asking your PB to use Pentair Intellibright LED lights instead of Hayward. Several have reported those going out after five years or so.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    The reason to have two drains is so that a person doesn't get sucked down to one. That is what the anti entrapment means. If you have any drains, you should have 2.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Jun 2014
    The Woodlands, TX
    167
    Curious to who you went with?
    8,000 gallon in-ground gunnite geometric. Wet Edge Satin Matrix. Triple overflow water feature.
    Hayward - TCell 15 SWG; TriStar VS Main Pump; SwimClear 425 Cartridge Filter; ProLogic 4 Automation, SuperII Water Feature Pump; Polaris 280 w/ Booster
    Link to my Build
    Aug 2013
    Houston, Tx
    94
    Still ironing out details with the front runner. Hope to make a decision in the next couple weeks.
