Thread: Question on Testing
    Jun 2008
    Lewisberry, PA
    31
    Question on Testing
    When running most tests, with most test kits, the instructions tell you to swirl after adding each drop. How important is that? For example, if testing FC and you know that it is approximately 10 ppm. Will it make a difference, in your results, if you add 10 drops then swirl, add 6 drops then swirl and then as you are getting close to the final reading go a drop at a time?
    Roger
    14 x 28 Vinyl Inground, 13200 gal., Hayward EC-65 DE w/1hp Superpump
    30,429
    Re: Question on Testing
    I think most of us do it the short cut way you are describing. I have been doing that for 6 years or so with no loss of accuracy (that I'm aware of).
    The CH test can sometimes give incorrect results if you add several drops at once. Adding several drops is fine with the FC/CC tests.
