Thread: Various positions for filter
    I have a Hayward SP 722 D what are the various positions like rinse waste filter etc. I do not have the manual and I can't find one online can someone help please thank you
    11K | IG | Plaster | Hayward Pro Grid DE 36cu.ft. (DE3620) | Hayward Max Flo (SP2805X T20) .75HP | Pool rebuilt in 2008 |
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Various positions for filter
    This should be the manual for your filter. On page 10 it has a parts diagram. Do you have part 32 or part 33?
    32 is a multiport and will have a dial something like this:
    33 is a slide valve. It will look similar to this:
    It only has two positions: filter and backwash.
    Which style do you have?
    Neither it has a twist and lock handle handle
    The filter control valve is a SP722-D
    The link you sent is the manual for the actual filter I think my question was misstated, my apologies
    Richard320's Avatar
    Jan 2010
    19,023
    Twist and lock is a slide valve. You only have two positions.
    http://www.troublefreepool.com/threa...EPAIR-REBUILD)
