Results 1 to 7 of 7
Thread: Put a deposit on a AG pool package" .... Need advice... CLUELESS!!!
    Jun 2014
    Chicago, Il
    3
    Hi Everyone,
    My fiance and I just put a deposit down on a pool. We have shopped 3 different pool retailers in Chicago and have literally been told 3 different things. We are so confused and are now questioning our original plan. Here is what we have on hold (forgive me if I'm forgetting something or don't have the terminology down)
    Pool: Wilbar Quest 15 ft 54in Stainless Steel Side Panel
    Filter:Hayward SwimPro 110 (debating on upgrading to the 150 for $20.00 more)
    Pump: Hayward Swim Pro 2Hp 2Spd (Great Escape recommended this... I've read it's overkill to have 2HP. We figured we'd run it on low majority of the time.)
    Sanitizing System: Nature2 Vision Pro Vessel Water Sanitizer (I know nothing about this!)
    I'm hoping for some advice on Filter, Pump and Sanitizer. I grew up with an 18ft pool, sand filter and no sanitizing machines, so this is all new to me and not to mention the last time I had a pool was 20 years ago!
    Side note: the 2Hp 2Spd uses 3 volts on low and 13 on high....
    Also, the "package price" comes with cleaning accessories (net,vacuum, etc) as well as basic chemical start up... Anything I should add?
    Thanks for reading and any advice you can give me! It is much appreciated!
    Have a deposit on:
    AG 15ft Round 54in/5500 gallons Wilbar Quest w/ stainless steel side panel
    Hayward SwimPro 110 Filter, Hayward SwimPro 2HP 2Spd Pump
    Vision Pro Nature Sanitizer
    Here to figure out if this package that I have on hold is sufficient...
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Put a deposit on a AG pool package" .... Need advice... CLUELESS!!!
    Hi Nina,
    Welcome to TFP and congrats on the upcoming festivities of Tying the Knot!
    I and all the other folks on the forum would urge you NOT to use the Nature2 sanitizer. Although the marketing material is appealing, it doesnt work well and induces copper and other metals into the pool which will turn hair green and can cause ugly staining of the liner. It's a bit of a nightmare to reverse the staining and getting rid of the copper. And its not a matter of IF, but WHEN. (At the top right of this page, there is a search box. You can enter Copper Sanitizers, Nature2 etc into the box to find more specific info).
    I would suggest replacing the Nature 2 with a saltwater chlorine generater for sanitizing your pool if your budget can swing it.
    If you can upgrade the filter for only 20$ more, do it.
    The 2 HP pump is definitely overkill that you dont need to pay exta for. You can easily get by with a 1 HP. The 2 speed feature is available on many many pumps, and is an excellent energy saving feature that you definitely want to have.
    Hope this helps!
    Good Luck on your new pool!
    Divin Dave,
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Hi there and welcome....
    I'd ditch the Nature 2 system... You don't need it.... You also need to get yourself a decent test kit... The best kit is the one this site recommends and you can get it here at this link...
    http://tftestkits.net/splash-page.html
    You also need to start reading Pool School.... This will teach you how to balance and manage your water without the need of a pool store.... You can ask as many questions as you like, there are heaps of people here with tonnes of experience to guide you thru this......
    You are right to go with a two speed pump and run it on low.... Upgrade the filter also.... Biggest filter you can get, with a modest pump.....
    Overall you're looking good...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2012
    western NY
    1,560
    Quote Originally Posted by Nina811 View Post
    Hi Everyone,
    For clarification, it uses 3 amps on low and 13 amps on high. This is pretty common for 2 speed motors. Again, as stated earlier, way too much pump for such a small pool
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2014
    Chicago, Il
    3
    Thanks Dave!! I appreciate your reply! This is so helpful!
    Quote Originally Posted by danpik View Post
    Thanks for the correction! Trying to get this down! Lol
    So, I called and ditching the Nature 2 won't bring down the cost of my package. It's free. I'm wondering of packaging even makes sense. The package includes the pool, filter and pump I wrote about as well as the nature 2, solar cover, maintenance kit, chemical starter, manual vac and cleaning accessories, free installation, but I'm responsible for sand, block and plastic. (Don't know if the upgrade to foam is worth the extra 300.00... Opinions?) i also have the option to do just foam coves with sand bottom for 100.00. So many options!!!! I never realized how many decisions I'd have to make in getting a pool.
    Have a deposit on:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Nina,
    there are a LOT of decisions to make.
    A pool is a long term investment and should be given a great deal of thought. If not, it can end up being a problem and costing a lot more money bring it to an enjoyable level.
    I suggest to step back from the folks you are dealing with now and perhaps do some more shopping around. What makes me say this is becouse of the guys comment about the Nature 2 being free. News Flash. Nothing is free in the pool buisiness!
    I bet you would do very well going into the pool place and TELLING them what you want instead of them telling you what they will give you. There are indeed TONS of options, but at the end of the day, its really not that hard to understand the difference between the frills and what you actually need on a pool.
    Divin Dave,
    Orlando, FL
    690
    I agree with Divin Dave. You should probably hold a moment, search around the forum for above ground pool builds to see what equipment people are buying, and then search around the internet for prices. I believe that you will find that some of the things the store is selling you are not needed or you can get better/cheaper by buying it yourself. IF the Nature 2 System is Free, then tell them you will take it. You can sell it on eBay or Craigslist. You could also buy your pool online (everyone gets them from the manufacturers - nothing special there) and then, ask the pool store what the cost to install it would be.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
