Thread: Above Ground Pool Sand Filter Leaking Need Help!!!!
    Jun 2014
    Cranston, RI
    1
    Hey guys, I have a Jacuzzi Laser above ground pool sand filter. It is leaking out water from the base of the filter. It is leaking the most on one side. The base where it sits in is full of water which leaks out from underneath. Is there supposed to be water underneath the filter. Maybe it is cracked underneath. Can anyone help?
    Casey's Avatar
    SW PA
    10,438
    Re: Above Ground Pool Sand Filter Leaking Need Help!!!!
    Hello and welcome to TFP.
    It looks like maybe you have a crack in the base of the filter. It should not be leaking like that and you more than likely need to replace it!
