Thread: Decking Choices, IPE? Treated? Trex?
    Aug 2011
    Middle TN
    83
    So we just poured our concrete and I've got questions about that in another thread but I left a 10x15 ft space for an essentially on-ground (2-4 inches above) wood deck just out of the backdoor. I'm considered whether "wood deck" really needs to mean wood and if so what type. I'm very interested in IPE decking, has anyone used it and if so where did you get it? I don't think I can find it locally. Good or Bad experiences with that?
    What are ya'll's thoughts on the various composite decking? Seems like the most ubiquitous is TREX but I know there are a bunch of different types. I'm not sure I LOVE the fake wood aspect but if any of you have that kind of decking and just love it I'd like to hear for you too.
    The theme being... what kind of "wood" should I use to build my deck?!?
    18 x 36 Vinyl Inground, Coverstar Cover, 2 speed Pentair Pump, Hayward 425 Sq Ft Cartridge Filter, Hayward Heat Pump, Prologic PS8, T-15 Salt Cell, 2 Colorlogic LED lights, TF-100 Test Kit
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Decking Choices, IPE? Treated? Trex?
    I would go with IPE. That is some beautiful wood and it will last virtually for your lifetime. Try Ipedepot although their are several suppliers you should shop and compare. Usually it is installed with ipe clips which gives you an unblemished look. Be warned that it is hard to work with. You will need carbide tipped cutting tools to cut it. Google IPE and click the images tab for some pictures.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    We're happy with our Choicedeck from Lowes.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    One thing to remember is that these composite products typically cost 3-5 times the price of wood. Depending on the climate a pressure treated wood deck can generally last at least 10-15 years with only minor maintenance and may go 20+ years before requiring significant work / redecking, so you really have yourself if it is worth the extra money.
    Ike
    We used Trex for our boardwalk
