Thread: FC & Water Heaters
    Jul 2009
    Ocean View, NJ
    10
    FC & Water Heaters
    Somebody had told me that with pool heaters, the FC should not go above 5ppm. I have looked online and not found anything to prove/disprove this. My chemicals are currently FC 3.0 CC 0.0 TA 90 CH 290 CYA 50 Ph 7.4 Borates 30 Water Temp 82. According to the pool calculator, I should be at at least 4 and could go as high as 8ppm. Can I do any damage to the heater if I go up to 8ppm?
    16 x 41, 24,500 gal fiberglass with 450 gal spillover spa; Pentair intelliflow VS, Pentair Clean & Clear 420, Pentair MasterTemp 250, X-stream 2 slide; aquabot breeze 4wd
    Re: FC & Water Heaters
    If you aren't using any CYA at all that is mostly correct. But as soon as there is CYA in the water the limit goes way way up.
