Thread: Hayward Diver Dave pool vac and intex sand filter SF80110
    Jul 2011
    Albuquerque, NM
    38
    Hi everyone. We upgraded from a cartridge pool to a intex pool with a sand filter. The sand filter is model number is SF80110 and it came with the intex pool. We also bought a Hayward Diver Dave pol vac but cannot figure out how to hook the two together. Any help would really be appreciated.
    Thank you.
    Jenn, From New Mexico
    8600 gal Intex 12x24x52 ultra rectangular pool, current filter: Sand Filter Pump with 1,600 gallon (6,056 L) per hour flow rate
    Re: Hayward Diver Dave pool vac and intex sand filter SF80110
    Did you get this figured out? I have a similar setup and hook mine to the wall intake with the supplied hose and cone connector. I do not use the in-wall skimmer and vacuum plate as this seems to introduce air into the pump and cause problems there. Are you trying to convert from 1 1/2" to 1 1/4"?
    30' AGP, 22" Sand Filter w/ 1hp Pump, Suction Side Cleaner
