Thread: Difference in suggested levels between Pool School and Pool Calculator
    Jun 2013
    Philadelphia, PA
    143
    Was just looking at the new styling of the pool calculator this morning and noticed the suggested FC levels there slightly differ from the suggested levels in Pool School. Any reason?
    At a 70 CYA level, (And suggested levels set to TFP, SWG and fiberglass) pool calc shows -
    While Pool School shows -
    I've always stuck to an FC of 5, but noticed the shock number if pretty different. . .
    Leisure Pools Riv 30, 8500 gal, IG fiberglass, 200 sqft cart filter (Clean & Clear 200), Intelliflo 3HP variable speed pump, Aqua Rite SWG, auto cover, installed 5/2013
    Aquacal Superquiet 110, installed 6/2014
    TFT 100
    Re: Difference in suggested levels between Pool School and Pool Calculator
    You should use PoolMath instead. Pool calculator is no longer being maintained and has not kept up with our latest recommendations.
    Jun 2013
    Philadelphia, PA
    143
    Ahhh, had no idea. Thanks!
    TFT 100
