Thread: Easiest way to figure gallons of water in the pool?
    tookiesmom07's Avatar
    May 2013
    Tennessee
    56
    I understand that you need to have a close estimate of how many gallons of water your pool contains for proper adding of your chemicals. But what is the best way to figure out about how many gallons your pool holds?
    Intex Ultra-Frame 26x52 AGP (14,650 gal.)
    Intex Pump & Filter
    Sastocky's Avatar
    Mar 2013
    Jackson, Ohio
    22
    Re: Easiest way to figure gallons of water in the pool?
    In feet, Length x Width x Average Depth = Cubic Feet of Water
    Cubic Feet of Water x 7.48 = Gallons of Water in your Pool.
    ***FYI, there are 7.48 gallons in a cubic foot.
    Southern Ohio, 18'x36', 8'x3' deep, Vinyl, Hayward 1hp Super Pump, Hayward Sand Filter, Hayward AquaRite 25k SWG, 5-3'x8' Solar Panels, Hayward AquaSolar, Aqua Pro 137k Heat Pump
    Taylor K-2006, Taylor K-1766, Taylor SpeedStir, hth 6-Way with OTO
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    At the bottom of this page is a calculator.....
    http://www.troublefreepool.com/calc.html
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Using a fas-dpd test down to .2 during a chlorine addition will get you darn close. Say take FC from 4 to 7 based on what you THINK your gallons are. Use Pool Math to calculate dosage required. If your check an hour later and your FC is either higher or lower than your target, your pool is either larger or smaller than what you calculated it at.
    Jun 2014
    Houston
    110
    For a "kidney shaped" pool, the calculator here seems fairly accurate..
    http://www.pentairpool.com/support/c...c/poolcalc.htm
    30 year old, 17,000 gallon pool (w/spa), IG, Plaster, Pentair Triton II TR-100 600#Sand Filter, Pentair Superflo 340043 1.5 Hp pump
    May 2013
    Tennessee
    56
    Thank you everyone!
    Intex Pump & Filter
