Results 1 to 7 of 7
Thread: What's wrong with my filter?
    May 2014
    Monroe, Louisiana
    32
    I vacuumed and cleaned filter baskets today, chemistry has been great.
    When the timer kicked on this evening, I could hear outside it was louder than normal. The filter basket at the pump (which from what I understand, needs to be full of water to prime and run correctly) was only about half full.
    It fills when I turn the pump off entirely, but as soon as I turn it on, it drops to about half. I've back washed and rinsed the filter, tried adding water to the basket, it just goes away.
    Is this an air leak? I had four rowdy boys in it earlier and the water level MAY be a little low. It's supposed to rain this week so I don't want to get over eager with adding.
    NE Louisiana
    25k gallon IG 16x30 vinyl liner pool
    Hayward Super Pump 1.5HP
    Intermatic timer, ~8hr/day
    Sand filter
    Casey's Avatar
    SW PA
    10,452
    Re: What's wrong with my filter?
    It sounds like a leak in the line somewhere.
    30,426
    Turn on the pump and go observe your skimmer(s). If there is air being sucked in, your pool water level is too low and needs to be raised
    May 2014
    Monroe, Louisiana
    32
    When I turn the pump on, the basket at the pump empties (not fully), and there is no activity at the pool. I've even tried running the hose into that basket to fill it but it's no use- it fills up when I turn the pump off. I'm adding some water now to see if that helps. Fingers crossed!
    NE Louisiana
    Sand filter
    30,426
    So you do not see any intake of water at the skimmer? Nor do you see any intake of air at the skimmer, correct?
    May 2014
    Monroe, Louisiana
    32
    Right. No bubbling at the jets, nothing.
    NE Louisiana
    Sand filter
    May 2014
    Monroe, Louisiana
    32
    Well, I did something right. LOL It seems to be working ow. I added a little water and checked to make sure the weir wasn't sticking, then let it run for a little bit longer. Voila!
    NE Louisiana
    Sand filter
