Results 1 to 9 of 9
Thread: hayward h250 issue...
    Jun 2014
    Holmdel, NJ
    5
    Started up my pool heater and it will run for an hour or so, then shut off and give me the "IF" error code.
    Gas pressure is not an issue, I have already checked the flame sensor and made sure it was clean and connected securely, and I have checked the burner orifices and made sure they were free of any clogs.
    It is a direct ignition heater.
    Any ideas?
    Jun 2012
    western NY
    1,560
    Re: hayward h250 issue...
    Will it restart after you clear the code? You say gas pressure is not an issue, how did you verify this.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2014
    Holmdel, NJ
    5
    Quote Originally Posted by danpik View Post
    Yes, it will restart, but again, it will only run for 30-45 minutes and then it will shut off and give me the "IF" code again.
    As for the gas, I am a union plumber and pipe welder. I put my gauge on the line, and had 9" wc at the valve. Not to mention that this same heater worked all last year.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    It can be the ignitor, it also acts as the flame sensor, or it could be the control board. How do you figure out which one it is? You replace one and see if anything changes. I would suggest changing the ignitor first.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2014
    Holmdel, NJ
    5
    Quote Originally Posted by ps0303 View Post
    I pulled the ignitor last night, and it was clean as well, no corrosion anywhere.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Just because it's clean doesn't mean it doesn't have issues. You have to to consider that it's heated all the time when the heater is on. The flames are surrounding it so over time the heat can fatigue the metal and sometimes cause the two wires to maybe lose their ability to sense flame. You are still at the point where you have to try and replace either the ignitor or the control board to see which one is the cause of the issue.
    Paul
    Jun 2014
    Holmdel, NJ
    5
    Ok, thanks.
    Jun 2014
    Holmdel, NJ
    5
    Is there any way to use a multimeter to check them without having to just randomly buy new parts in hopes that they work?
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Not really. Swap one out first and see what happens. Some parts just can't prove if their good or not. I can tell you that 90% of the times it's the ignitor.
    Paul
