Thread: Adding DE to speed up clarity
    I am in the process of transforming my swamp. I have been passing OCLT and I decided to try adding some DE. It takes my sand filter about 4 days to go up 1 psi. I added enough DE to bring my pressure up by 1 and 10min later I had to BW. The water was very dark and dirty. I added the same amount of DE and in another 10 min I had to BW again but this time the water wasn't as dark. Is it normal to rise so quickly when trying to clear your pool?
    24000 Gallons
    Cristal-Flo Hi-Rate Sand Filter
    IG - Vinyl
    3/4 HP Pump, and 44 Flow Rate
    Older than 10 years.
    38,548
    Re: Adding DE to speed up clarity
    If the water is very dirty, yes. That is the point of the DE.
    Thanks Jbizzle. Yes the water is very dirty. I wanted to make sure that there would be no issues with the frequent BW. At this rate I could blow through a 10lb bag lol.
    24000 Gallons
    IG - Vinyl
