Thread: Caretaker 99 pressure
    Jun 2014
    Phoenix, AZ
    50
    My in floor system works pretty well at 20 psi, but I only get that pressure if the main return is closed. With both returns going the pressure is maybe half and it doesn't effectively push (they barely pop).
    Is this an indication that the pump motor is inadequate? Or is it intended for the in floor cleaner to be the only return? It's been this way for 5 years since I bought the house and I always chalked it up to a bad system. Maybe I can address it now that I'm a TFP member.
    ~12,000 gallon IG pebble pool. Pentair CnC Plus 4-cartridge system, AO Smith 1.5hp single speed
    Re: Caretaker 99 pressure
    When the in-floor system is in use it should be the only return. Some people automatically switch between regular returns and an in-floor system, so each runs part of the time.
    Jun 2014
    Phoenix, AZ
    50
    Thanks Jason. I wish I had an automatic switch, but I don't. Just a few aging 90 degree shut offs.
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    normal operation for the 5 port is between 15 - 19 psi, this depends on how many heads you have per line. if you can reach these pressure then you are ok, if not then you can replace the pump with a bigger one but make sure you talk with a pool professional first to make sure the pump and the filter are compatible, too bigger pump can damage your filter and cause bad filtering.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Nov 2015
    Scottsdale/AZ
    62
    I have a similar issue. I also have an Aqualink system, so would you suggest putting an automated Jandy valve in the manual valves current position and setup a program that would automate manually changing this? Is so, what would that program be set at? For instance, if the pump is run for 9 hours per night turn the Caretaker valve to fully on for 6 hours and then move back to jet return for the other 3 hours ? Also, how do I know if my Aqualink has enough room to add another valve? Thanks!
    16,000 gal Pebble Sheen pool w/ spa, Jandy Aqualink, Hayward Salt system, 60 SF DE Filter, Hayward Gas Heater, Caretaker In-floor pop-up cleaning system.
    2hp Whisperflow for filter, 2hp Dynaglass for booster, 2hp for blower, 1hp Dynaglass for scuppers.
