Thread: return jets up or down / circulation
    Jul 2013
    Cedar Rapids, IA
    82
    Here's a rough drawing of the lay out of my pool. I aimed my returns upward after removing them, giving them a good scrubbing with a toothbrush, and laying down some fresh thread tape. I like aiming them toward the surface because it creates a calming babbling brook ambience, and I was wondering if given the layout of my pool could I get away with aiming my jets toward the surface and at same time get good circulation and skimming?
    I do have a 9 foot deep end on the skimmer side and was worried that I may not be allowing my water proper circulation.
    As always thanks in advance for any suggestions or advice.
    I apologize in advance for this drawing. lol
    http://s284.photobucket.com/user/ble...mo_01.jpg.html
    24,300 gallons, IG vinyl, Hayward Pro Series S244T sand filter, 3ft to 9ft deep
    Re: return jets up or down / circulation
    If the returns break the surface they will create a fair bit of aeration. That may or may not be a problem depending on your TA. High TA plus aeration can raise the PH fairly quickly.
    You want to aim the returns so that you get consistent water movement through the pool, typically in a circular pattern. It is also a good idea to aim at least one return downwards to make sure you mix in the deeper water.
    Jul 2013
    Cedar Rapids, IA
    82
    Quote Originally Posted by JasonLion View Post
    If the returns break the surface they will create a fair bit ofbetweenon. That may or may not be a problem depending on your TA. High TA plus aeration can raise the PH fairly quickly.
    Interesting, didnt know it affected TA and Ph. Right now TA is right around 80 and Ph between 7.2 and 7.5. I do have a drain in the deep end and I wondered if that would help circulate the water more. Does that help or should I just re-aim my returns?
    Thanks again.
    Having a main drain greatly reduces the need to aim any of the returns down.
