Thread: R-7065 Standard CYA Solution?
    May 2012
    Flower Mound, TX
    130
    I need to order some more chems: R-0013, maybe some borate strips. But checking out the TFTestkits they also sell R-7065, R-7064, R-7063 Standard Solutions.
    Questions
    1) Are these worth having?
    2) How do you use them?
    3) What is the purpose for them?
    Thanks, John
    14,000 gallon IG DiamondBrite pool with 2 ea. waterfalls and slide, Hayward Tristar 2.0 HP 2-speed pump, Hayward 3/4 HP waterfeature booster pump, Hayward 48sf DE filter, Hayward PS4 wireless controller, 1 skimmer and 4 returns, Polaris 280 pressure cleaner w/booster pump, 7 x 7 spa w/6 jets, TF-100 Test Kit w/speed stir
    38,354
    Re: R-7065 Standard CYA Solution?
    I think the CYA standard is good so you can confirm you are doing the test in the correct light. The others are not likely needed.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    The standards are a set level that you can test to check your reagents as well as to verify your testing methods. Since the CYA test is so subjective I recommend that one so you can train yourself what the vanishing dot should look like. The others probably aren't as useful.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    May 2012
    Flower Mound, TX
    130
    OK, GOOD. I will order some today.
    Thanks, John
    30,426
    Confirming the above thoughts, our customers certainly agree. We sell FAR more of the R-7065 (CYA) than we do R-7064 (TA) or R-7063 (CH).
    Most of that has to do with the CYA test being a bit hard to interpret and having that standard solution gives you a comparison.
