Thread: DE fliter leak
    DE fliter leak
    Hello,
    I have a DE filter that is running at 20psi, and seems to work fine when the pool pump is on, but when the pool pump goes off, water streams (not trickles) out of the top the DE filter. Any idea what is causing it? Appreciate any help you can give me...thanks!
    12.5K gallons, AG - 15x30 oval, 2 hp 2 speed Pump, 22" Sand Filter, 25 sq ft Cartridge filter, AstralPool VX7S Salt Chlorinator, TF-100
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: DE fliter leak
    You have a leak in an o-ring. It may seal fine when the pump is on and the pressure is higher but loosen up when the pump is off. Is there a fitting where it is leaking (e.g. air release, pressure gauge, valve, etc)?
    Mark
