Thread: Pool Spa Leak - should the leak water have traces of chlorine?
    Jun 2014
    Laguna Hills CA
    1
    Yesterday I had a pool leak detection done on my pool because of excess water in the adjoining flower bed and also because over the last couple of years it just seemed like I was putting water in too frequently (about every 5 days). Although it was not detectible in my water bill. I was told that our spa has some leaks which he attempted to fill with epoxy (said may not work or be temporary only). All the pool plumbing lines were fine. So in flower bed next to the spa I had dug a hole and have a small pool of water. I have emptied the pool of water and over night again it will slowly refill. I have tested this water and so did the pool guy and we can find no trace of chlorine in it. Should there be chlorine in the water in my flower bed or because its been in the dirt and may take a while to this spot its just gone? If the results of the epoxy don't work and I have to repair the spa I just want to feel confident the water is really coming from the spa and not my sprinklers. Oh, and I had the gardner check the sprinklers. I was thinking that if I have to repair the spa I would drain the spa for a week or so and see if the excess water in the hold in the flower bed goes away before I fix it?
    Should there be traces of chlorine in that excess leaked water? or does the dirt take it away? Any other ideas?
    First time post...glad I found this site.
    thanks
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Re: Pool Spa Leak - should the leak water have traces of chlorine?
    I doubt the dirt would filter the chlorine out. Are you sure 100% its not a sprinkler?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
