Results 1 to 8 of 8
Thread: dirty water comes back into pool while vacuuming?
    May 2013
    Syosset, NY
    12
    I posted a few weeks ago about the lack of return water and the fact that I haven't cleaned my DE filter since I bought the house (3 years ago). So I took it apart following the sticky here (THANK YOU!) and cleaned - there was about 40+lbs of DE that I took out. Hosed everything down, put it back together turned the pump on, mixed about 4+lbs of DE in a bucket and poured into the skimmer and boom - worked like a charm!
    So I wanted to keep the filter on for a entire week and let it work. Last weekend I decided to give vacuuming a try since there was a lot of dirt on the floor of the pool. After about 10 min of vacuuming though, I noticed that the water returning to the pool was basically what I was vacuuming! I stopped immediately, backwashed it and then put in another 4+lbs of DE (this time closer to 5). Tried to vacuum again during the week and same result - dirty return water.
    Did I possibly not put the filter back together properly? Any other idea on whats causing this??
    dr
    20K gal, IG vinyl, DE filter
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Re: dirty water comes back into pool while vacuuming?
    Could be one or more things. Bad spider gasket in your multiport valve is the likely cause since it only happens when you are using the waste selection. That could have had some impact on your low return flow prior to cleaning as well.
    If there is some chance that you turned the multiport valve from 'filter' to 'Vac' or another setting while the pump was running that is the likely cause. Changing the selection without turning of the pump off is bad for the gasket.
    Since you just had the filter apart there could be a slim chance of the following causes. But these most likely would cause DE to be blowing back into your pool with the filter running as well. If you don't notice DE coming into pool from returns when pump starts, don't consider these likely causes:
    - Cracked/brittle o-ring on the outlet elbow (pipe where the top manifold sends water out).
    - Grids not aligned properly, which could allow some bypass where the each grid goes into the manifolds.
    - Small holes or tears in grids.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    What happens if you vacuum to Waste instead of Backwash?
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    30,402
    Could it be that your filter is simply doing what it is supposed to do? It sounds like it is RAPIDLY filling with debris and, now that you have re-established good flow, the clogged filter is simply bypassing the pressure on the multi-port Spring and blowing out unfiltered and debris laden water.
    Despite that rather convoluted guess of an explanation, the proof of that happening is really easy.
    1. Clean and backwash.
    2. As soon as your filter starts to spew debris into the pool, clean and backwash again.
    3. Repeat. If I am guessing correctly, the time in between clogging the filter will get longer and longer as you clean out more and more junk.
    Do you think your pool can be that dirty? Got a pic?
    May 2013
    Syosset, NY
    12
    I hope the filter is operating properly!! Honestly had no idea of multi-port spring. I will try this tomorrow am first thing. After I backwash I do need to add in another 4 lbs of DE and then vacuum - correct?
    Thanks!
    dr
    30,402
    The explanation was overly-complex.....I'm sorry.
    It sounds like your pool is really dirty, it is sucking up a lot of debris very fast....clogging the filter. This can allow the multiport to release debris back to the pool.
    The important thing is the fix. That is simply to keep cleaning and backwashing and filtering. You're just gonna' have to do it a lot...over and over...until the pool get's clean enough so that the filter doesn't clog so often. Keep us posted.
    You could just need a little sealant around the o-ring on the outlet elbow. Also you don't need to added the full amount of DE after back washing the filter. You never really remove all of the DE during back washing. What your doing is basically just recharging your DE
    Using Tapatalk
    Dec 2010
    San Diego, CA
    1,137
    What kind of filter and valve do you have? Sorry if I missed it but not all have the bypass being talked about.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
