Results 1 to 8 of 8
Thread: A few questions
    A few questions
    There are a few minor clarifications I'd like to ask from the experts. My numbers this morning were as follows:
    FC: 2.5
    CC: 0
    TA: 80
    CH: 270
    CYA: 25
    I have three questions:
    1) I know my CYA is low. My SWG has no problem maintaining FC at this level though. I generally run it at 30-35% and maintain a FC range of 2.5-4.0. I think the VSP helps here. Is there any other motivation to increase the CYA?
    2) When I measured the TA, after the change of color, I had some particles in the solution. I've never noticed this before, but did the test a second time and the same thing happened. Does this tell me anything? For example, it's possible that one of my chemicals is older and I'd like to make sure that it's not unreliable. Also, just curious.
    3) I accidentally did my chlorine test in the container that is not labelled "Chlorine Only" (i.e. the one I use for all my other tests). Does having this happen one time cause any issue? Is there anything I should do to clean it out properly?
    Thanks
    Tom
    27,000 gallon, 3M Quartz, SWG, Hayward EcoStar SP3400VSPVR (2HP variable speed pump), Pentair Quad DE filter[/color]
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: A few questions
    1) To reduce wear on your SWG.
    Someone else will answer the other questions.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: A few questions
    +1 what he said about the wear.
    What kit do you have and how old are the chemicals ??
    To clean out the container you used for the chlorine test you might use mild soapy water but just rinsing it with tap water if it's plastic should be enough.
    Solar Blanket, Well Water, Borax Added. 76
    Re: A few questions
    1) There are many small advantages to increasing CYA. The largest is that your SWG will last more than twice as long. Your chemistry will also be much more stable and much less prone to getting into problems.
    2) Not important. Various things can precipitate out. That is rare, but not at all unheard of.
    3) No problem. Over time the FAS-DPD chlorine test will cause the tube to get cloudy. Keeping a separate tube for that avoids problems reading the other tests through the clouded tube. One use won't make enough difference to notice, only many many uses.
    Oct 2013
    Chapin, SC
    1,141
    Re: A few questions
    And that it says chlorine only is really only a way to charge you an extra 50 cents for the label. Oh, and it's not graduated to do a pH test (44 ml) as long as you rinse it after each test, it really doesn't make any difference. When my tube gets a little cloudy stained, I just get a piece of paper towel and wipe it clean--clean as new!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    May 2013
    Bay City, Michigan
    283
    Re: A few questions
    so your SWG is running at 30 to 35% and your maintaining enough FC for your CYA levels....but how long are you running your pump? Also things may change when the weather gets hot and really sunny, and your water gets warming, your current program may no longer be able to keep up.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Re: A few questions
    what the others said
    Divin Dave,
    Re: A few questions
    Thanks for all of the feedback. The wear on the SWG makes sense, so I'll start adding some CYA. My VSP runs all the time at a lower speed, except a couple hours a day at high speed, so I think that's what let's me run the SWG at a manageable level. Less wear seems better, though.
    Good inputs on the other two, as well. I won't sweat either one.
    Happy swimming to all.....
