Thread: How Did You Cut Your Rigid Foam Board for Under Your Pool?
    PPrince's Avatar
    Jul 2013
    North Coast of Ohio
    55
    Hoping to arrange, cut and lay down rigid foam insulation boards for our 18' round pool. I am just wondering where people started? In the center of the pool and work out or start at one side and go from there? I know there will be some pieces cut to size and wondering if people tried to locate toses around the edges or in the center? Kind of like tiling a floor, you plan ahead so that you don't end up with small tiny pieces around the edge if you can avoid it. Since I am working with 4' X 8' sheets and cutting them to fit a round pool, where do I want to put the "smaller" pieces?
    I put together two quick layouts. (Hope they post okay.) One starting it "the upper left" of the diagram using a full sheet and the other starting in the center and working out. Hopefully you can follow this better with an illustration.
    What did you do?
    Paul
    8000 gal 18' x 48" AG steel wall pool, 1 HP Hayward Perflex DE filter, SWG, Jandy Lite 2 Heater - 175K BTU
    Jun 2013
    Middlesex County/VA
    50
    Re: How Did You Cut Your Rigid Foam Board for Under Your Pool?
    THe installer started in my center and worked out staggering joints. He also cut and fitted before wall went up. Makes it easier. just don't do like he and tape and install before wall do that after wall is installed.
    Pool Size: 24' Lomart Whispering Wind II 13000 gallons
    Pool Type: Aboveground
    Pump:Hayward 1 1/2 HP Power Flo Matrix 2 Speed
    Filter: Hayward S230T 250lb Sand Filter
    Aug 2013
    south east Arizona
    197
    please excuse my drafting progream, er I mean cruddy ms paint abilities but this is how I did mine. 12 sheets with one (in red) cut in half.
    so far the excess "corners" are either just breaking off or still sitting there unattended. sigh. I REALLY need to work on the ground around my pool, but I can hardly see it from the inside so I am not very motivated in that respect.
    somewhere around 6,800 gal 18 x 4 foot round Intex Ultra Frame AG, finished filling August 29, 2013. toy pump w/ "A" cartridge up and running next day --- July 2015 upgraded to Krystal Clear 3000 GPH pump and 16" sand filter --- May 2016 Intex auto cleaner and in July salt system and Hayward skimmer
