Thread: Poollink
    Jun 2014
    Canada
    2
    Poollink
    Hello
    We have a pool 25feet by 20 feet and 4 feet deep salt water.
    And we have pool link automated chlorine generator
    I want the automated machine to generate chlorine to our pool .
    Any one know how do I set it up
    I don't know a lot about it so I need help
    Thanks
    Re: Poollink
    Welcome to TFP!
    You can start with the article on Water Balance for a SWG.
    Jun 2014
    Canada
    2
    Re: Poollink
    Yes thanks I was reading , but still not really understood
    How to adjust the "cl " so it's generate chlorine.
    Any help
    Re: Poollink
    That is a PH and ORP based chemical automation system. There must also be devices to feed acid and chlorine to the pool. The acid feed is either a peristaltic pump or a CO2 gas dispenser. The chlorine feed is either a peristaltic pump or a SWG.
    Setting up a system like that and keeping it working is a fairly large project, not something I recommend for a residential user. If you want to get that working you will need to figure out what kind of PH and chlorine feed systems you have, get them setup, check and possibly replace the PH and ORP sensors, find the manual for the controller and get it setup, and then hope that all of them are still working correctly.
