Page 1 of 3 123 LastLast
Results 1 to 20 of 57
Thread: need help on chlorine , stabilizer and algicide
    my pool is approx 85000litres
    so my chlorine is at 1.5ppm how many litres of chlorine do i need to raise it 1ppm
    also my stabilizer level is 50ppm, should i remove the stabilizing pucks so that the levels drop? also should i place is floater or in skimmer i notice in skinner they get used up quicker
    how often should i use algicide and shock the pool?
    thx
    18x38 IG
    Appox. 85000litres
    Jacuzzi laser sand filter
    1hp pump
    Municipal water
    38,251
    Re: need help on chlorine , stabilizer and algicide
    Use PoolMath to do the dosage calculations for you.
    Your CYA at the top of the recommended range, so you have to stop using them. Never put them in the skimmer without the pump running. Your CYA will not drop just because you stop using pucks.
    With proper FC levels, you never have to "shock" or use algaecides.
    May 2013
    Bay City, Michigan
    283
    Responses are in red and blue
    Quote Originally Posted by wantboost View Post
    so my chlorine is at 1.5ppm how many litres of chlorine do i need to raise it 1ppmThis all depends on the chlorine strength your using. There is 6% and 8.25% bleach, and 10% and 12.5% liquid chlorine. Either way, the pool math tab on the top of the page can help you with that. 1.5 or even raising it to 2.5 PPM is to low for you 50 CYA. You've been here since 2013, I assume your familiar with the CYA/chlorine chart?
    also my stabilizer level is 50ppm, should i remove the stabilizing pucks so that the levels drop? also should i place is floater or in skimmer i notice in skinner they get used up quickerYou should remove the pucks so it doesn't go any higher, but the levels don't just "drop" they get reduced only when you add fresh new water either after draining, backwashing or splashing out...replacing water after evaporation won't lower it any either. You should not place them anywhere, at 50 CYA you should not be using them anymore unless you are using a SWG and your trying to get higher CYA levels.
    how often should i use algicide and shock the pool? Usually, and with proper care you can never need to shock, and algicide is not necessary or really recommended using the TFP method.
    thx
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    OK I ll call my pool store and ask how strong there chlorine is
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    May 2013
    Bay City, Michigan
    283
    Most bottles should have it listed on the bottle or label. It would show somewhere with "active ingredients" then ***% Sodium Hyperchlorite
    They refill bottles for me. So this does not sound right 1000ml of 10% bleach will raise the pool 1.1ppm?? Is that what the stuff from pool store is considered?
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    May 2013
    Bay City, Michigan
    283
    I would GUESS 12.5%...at least in the US, it seems pool stores carry 12.5% liquid chlorine, big box stores like home depot, wal-mart carry the 10% liquid chlorine, and the 6% and 8.25% is household bleach strength.
    May 2013
    Bay City, Michigan
    283
    Looking at your first post, and your signature... Your post says 85000 litres and your signature says 13800 gallons..
    85000 litres = 22454 gallon
    13800 gallon = 52239 Litres
    Not sure which to use.....
    I edited my signature. Have a different pool now. 85000l approx
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    May 2013
    Bay City, Michigan
    283
    okay, so using pool math - http://www.troublefreepool.com/calc.html
    85000 litres and to get a 1PPM fc rise
    1002ml of 8.25%
    826 ml of 10%
    661ml of 12.5%
    Of course there is the variable of very fresh chlorine being higher % than listed, and older or poorly stored chlorine being lower than listed.
    Wow that little chlorine
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    May 2013
    Bay City, Michigan
    283
    Well, your CYA is 50 according to you, and the TFP method and the CYA chart recommends never having less than 4ppm fc....
    http://www.troublefreepool.com/conte...art-slam-shock
    Oct 2013
    Chapin, SC
    1,141
    Don't confuse him, the pool store tells him fc of 1-2 is perfect and cya is irrelevant!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Pool store said 3.5 fc and they told me my cya is high
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    Ok
    I got my fc to 4ppm. Roughly how often r u guys adding chlorine. I know depends on how hot it is out and how many people using the pool etc...
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    Most people add chlorine once a day.
    How long should I be running pump 1 full turnover or 2? In a day
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    38,251
    Read this: http://www.troublefreepool.com/conte...-pump-run-time
    Turnover is meaningless.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Ok
    You need this: http://www.troublefreepool.com/conte...etting-started
    Most people test daily and add daily. The cheap kit from walmart, homedepot ... will keep you from running to the pool store daily but it is what it is, a cheap kit that will do some of the needed testing but not all.
    4ppm FC is the lower limit for your level of CYA. You want to try and keep it around 6ppm and not let it get below 4.
    If you know you are going to have people over or a party then that day you might want to go to 8 or more depending on your experience. This is where keeping a log with short notes on temperature, number of swimmers, sun-rain ... comes in handy. You can "see" in your numbers what was changed from one day to the next with a number of people in the pool. You can tweak your pool chemistry in relation to what you've learned from other "swim parties".
    Solar Blanket, Well Water, Borax Added. 68
  20. Back To Top    #20
    My fc got down to 1-1.5ppm.i just added 150g of hth shock how long do I have to wait till I can swim??
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
