Thread: Cloudy Water
    Cloudy Water
    Hey friends.. I need some help.. My test results are below
    Cl. 3.0
    Ph 7.5
    Ta 150
    Th 300
    My pool is still slightly cloudy. Thanks in advance!!
    24' round
    54" deep
    1 hp dynamo pump with sand filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Cloudy Water
    Hey Kyle,
    We really need some more info. Do you have a Cya number, or a kit you can run it with?
    Just guessing without knowing makes me lean toward too little FC. If the TH number is right it isn't high Calcium. If you don't have one, a good test kit would be at the top of the list of my suggestions.
    Essential Links:
    Casey's Avatar
    SW PA
    10,453
    Re: Cloudy Water
    Still cloudy from when?
