Thread: Calcium hardness and vinyl liner
    Jun 2014
    Mebane, NC
    27
    This has nothing to do with my other thread and pool issue
    So I now understand after reading here as well as other documentation that CH is not something people with vinyl liners need to worry about unless it is too high.
    Here's the thing that others might like to know as well.
    I had a pool store employee tell me, after they agreed of the need for CH in plaster and concrete pools, that you do need it in vinyl pools too because without the CH the liner will get brittle.
    I just smiled and nodded. lol
    Am I correct in that that statement was bunk?
    18360 gallon; Vinyl IG; Pentair SuperFlo High Performance Pump w/3HP ecotech EZ variable speed motor; Hayward S-200 sand filter; Dolphin Supreme M4 cleaning robot; Taylor K-2006 test kit
    Re: Calcium hardness and vinyl liner
    You are correct, the pool store person was wrong.
    The liner has no problem with low CH levels. It is low PH that is the most common cause of the liner getting brittle.
    30,403
    I think the answer is that there is no REALLY definitive answer.
    We (the forum) all know that too much CH in any pool is a bad thing......that's easy enough
    We also know that too little CH in a plaster pool is not good in that the water can actually "steal" CH from the plaster. So, we generally say about 250 ppm minimum for a plaster pool.
    It is not completely clear to me (but maybe others?) that there is an absolute minimum CH for Vinyl pools.....and if there is, I am not sure we definitively know why or even why not.
    The forum has pretty much taken the position there is no minimum but I am not sure we have ever received validation from a manufacturer of liners.
