Thread: New $25 Carb = new lawnmower
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello All,
    I've got a 1995 Toro self propelled mower that was giving be fits. I knew it was a carb issue, cleaned it, but it kept gunking up. I knew it really needed to be dip cleaned but didn't want to have the chemical cleaner around. Checked on eBay and got a new replacement for $25 bucks delivered. 5 minutes to swap it out. Primer bulb, pressed 3 times, first pull, started right up.
    Life is good.
    Nov 2013
    Ramona, CA
    46
    Re: New $25 Carb = new lawnmower
    Sounds like $25 well spent!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Now if only they could make a small pod like they do for dishwashers or laundry detergent that you toss in the pool at the beginning of the season with all the chemicals needed for the year for $25 !!!!
    Solar Blanket, Well Water, Borax Added. 76
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    If that is the first significant repair you have done to that mower, I would hang on to it as long as you can.
    I'm a fan of the Briggs flathead design. I have three of these (2 were discarded by neighbors and I took them off their hands). All they needed was a carb diaphragm for about $4. They all start on the first pull nearly 100% of the time. This design excels in its simplicity.
    Apr 2011
    Murrieta, CA
    2,360
    Yeap, first significant repair, bought it used, it even had records. Cannot complain.
