Thread: How am I doing?
    How am I doing?
    New liner and fill a month ago.. attached is my progress so far.. CYA is at about 40 so now is probably a good time to switch to LC correct? We have a well so I am thinking 1qt a month of metal removal should suffice. PS only has this PoolStyle stuff.. this ok or should I switch to Jacks or HTM?
    2003 Marquis Euphoria - 400gal
    Jan 2013
    Houston, TX
    1,079
    Re: How am I doing?
    Spot on - time to go Liquid.
    Watch that FC level - make sure it never drops below the target range. (dose to the top and let drift to the bottom of the range).
    Do you know there are metals in your water?
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Re: How am I doing?
    Your numbers look good, except the swing down to 1.5 FC today. Your CYA 40 dictates minimum FC of 3ppm. Get the LC in there pronto, today.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Re: How am I doing?
    Added LC... according to PS my metals are iron 2ppm. How can I test myself?
    38,237
    Re: How am I doing?
    Buy an expensive metal test kit ... or trust the pool store for that.
