Thread: Question about TA
    Jun 2013
    Bucks County PA
    94
    Question about TA
    Hi and thanks so much for being here.
    I added MA yesterday to lower my PH from 7.8 so I can eventually add Borax to help stabilize the numbers and get that sparkly water thing going on.
    My TA before adding MA was 90 - This morning it is 90, possibly 95 - it took an extra drop to get the sample to truly turn red. At 9 drops it was pale pink.
    1.How is it possible that the TA would stay the same, even rise after adding MA yesterday? The PH did drop to 7.0-7.2
    2. I didn't think it would have anything to do with the stabilizer I added yesterday to raise my CYA - but could it?
    3. Is it ok for the kids to swim with the PH so low? Should I ban them until it goes up a bit from aeration, or make them part of the process?
    As much as I would love to tinker with PVC pipe and build my own , I am heading out to pick up a fountain to aerate.
    Numbers this morning:
    FC 2.5 CC 0 PH 7.0-7.2 TA 95? I did not bother checking CYA today - since I just added stabilizer in the sock yesterday.
    Last time I checked CYA 45-50
    I have a SWG set at40% run time 8 hours a day
    22Kgal (18x36 3.5-6ft), IG,Vinyl,DE 36sqft Filter -90GPM flow rate, Pentair Whisperflow Pump,SWG Intelichlor, UltraTemp Heat Pump, New 10/2012 Bucks County PA
    38,254
    Re: Question about TA
    1. One MA addition may not be enough to lower the TA beyond the accuracy of the test.
    2. No
    3. It is fine, might be a little irritating to the eyes. They can help you aerate to get the pH back up.
    Jun 2013
    Bucks County PA
    94
    2. No
    Thanks so much - I realized now that we had some rain and that might have affected the TA too
